4 Replies Latest reply on Oct 20, 2014 2:32 AM by pirprod
    After Effects (and Premiere) CS5 do not run on a Dell Precision M90 - I Need Help!
    mad* Level 1
      I just installed the CS5 MC on my Dell Precision M90 on Windows 7 64 bit Pro.
      Graphic-card is a NVidia Quadro FX2500M.
      Unluckily After Effects an Premiere do not run. There seems to be something wrong with the OpenGL and I've no idea how to fix it. I use the newest drivers I could get and tried to install different nvidia drivers to find out if I can use a different (newer) driver. In this case, the installation is canceld by the installer. Baybe there is a workaround?
      Here ist the what AE says in German - I'll try to translate it.
      After Effects Fehler: After Effects ist bei dem Versuch Open GL zu initialisieren abgestürzt. Wenden sie sich wegen eines mit Open GL kompatiblen Treibers an den Hersteller Ihrer Grafikkarte.
      Translated: After Effects crashed when tryed to to initialize OpenGL. Contact your Graphic Card manufakturer for a compatibile driver.
      The following message is:
      <1212><AppDirs> Required Dir=  C:\Program files\Adobe After Effects CS5\Support files\Required
      and then ...  adobe support....(2)
      (0§42)
      I hope this was correct translated and you guys can help me.
