1 2 Previous Next 42 Replies Latest reply on May 21, 2012 1:55 AM by juliewales
    Captivate 5 : "Loading..." Screen
    salvador_sorianojr Level 1
      Hi Everyone,
      I am running a Captivate 5 Trial version for few days, and I am hoping somebody could share ideas on how to remove this gray "Loading..." screen.
      Everytime I publish a SCORM (1.2) compliant pproject this gray screen always pop in, either running it locally or via our LMS. I have observed that when I publish it without Reporting selected it won't appear, so I suspect it has something to do with the SCORM setting in Captivate 5.
      I have seen a similiar thread here and applied what has been approved as a fix and safe solution but didn't work either.
      Anybody else who got ideas?
      Thanks.
        • 1. Re: Captivate 5 : "Loading..." Screen
          Allen_Partridge-1MiBZx Adobe Employee
          Can you let us know the LMS and the browser you are using please? Also, how large is the project? Are you using the preloader? and at what percentage?
          Allen
          • 2. Re: Captivate 5 : "Loading..." Screen
            We are using SABA as our LMS and IE version 7. Wether I include our own preloader, which we usually set to 100% or using the default Captivate 5 preloader the gray loading screen still appears. Moreover, even publishing just two plain slides with enabled reporting the screen still appears.
            Thank you.
            • 3. Re: Captivate 5 : "Loading..." Screen
              Marking this thread answered.
              Thank you Manish for the assistance and for the solution of course.
              Best Regards,
              Miguel
              • 4. Re: Captivate 5 : "Loading..." Screen
                M_Anand Level 3
                You are welcome Miguel.
                For everyone who is facing this issue:
                - You can download the 'CaptivateMaintimeline.as' file from here
                - Place this file at: <root>:\Program Files\Adobe\Adobe Captivate 5\AS3
                -Manish
                blogs.adobe.com/captivate
                • 5. Re: Captivate 5 : "Loading..." Screen
                  Cristian_M Level 2
                  This solution does not seem to work for me, not even when running the presentation locally.
                  Just after the preloader, I always get the "Loading..." gray screen. What could I be configuring incorrectly?
                  • 6. Re: Captivate 5 : "Loading..." Screen
                    Greg Scholz Level 1
                    Manish,
                    This fix works for me - removes the gray 'Loading' screen.
                    Do you know if it will have any effect on AICC reporting?
                    Greg
                    • 7. Re: Captivate 5 : "Loading..." Screen
                      Macnimation Level 1
                      This fix worked form me also
                      • 8. Re: Captivate 5 : "Loading..." Screen
                        Xeon64 Level 1
                        I am having the same exact thing happening and I can not figure it out. I have Connect Pro 8 and Captivate 5.
                        • 9. Re: Captivate 5 : "Loading..." Screen
                          AICC
                          Manish,
                          Will this also improve the problem with the preloader not working correctly?  For example, I have a course which I would like to start playing after 5% loaded.  Will your new action script file.  Fix this too?
                          SEE THE POST HERE?
                          http://forums.adobe.com/message/3659244#3659244
                          -doug
                          • 10. Re: Captivate 5 : "Loading..." Screen
                            Xeon64 Level 1
                            I am confused as to what you are asking. What action script file are referring to? I do know the preload feature that comes with captivate does not work well and that the setting the load percentages does nothing.
                            • 11. Re: Captivate 5 : "Loading..." Screen
                              AICC Level 1
                              Xeon64,
                              Since you have also discovered the problem in captivate 5 (w/ the external preloader animations and w/ the field in the publish settings), is their another mechanism you use to get around the inconsistency?
                              About my post:
                              When Captivate 5 is installed, several action script files are dropped into the installation folder.  I started searching through those files (as mentioned above).   The folder i am speaking of is here (windows 7 64bit OS):  C:\Program Files (x86)\Adobe\Adobe Captivate 5\AS3
                              Many different actionscript files are located in this folder.  I was hoping someone would know if these files are comiled into the published swf, and if they are compiled into the published swf....are these the correct files to alter for the preloader?
                              I have written many preloaders in AS2 and yes they were not entirely accurate, but they did give a resonable level of percent loaded..  I actually wrote an entire shell loading external content (swf, jpg, mp3) into a main timeline which presented the course material using xml files as the storyboard.
                              Captivate 4 used the actual timeline when determining how long to show a screen or audio file.  In other words, if an audio file was 35 seconds.  You would see the audio file shown across 990 frames(@ 30 frames a second).
                              Captivate 5 does not use the timeline anymore.  Captivate 5 actually analyzes all of the objects in the course and uses variables to determine the movement and timing in a course.  Captivate 5 also uses AS3.
                              Last night,  I saw an option to export a captivate course into flash.   I am going to look into this option.. to fix preloading.  I may also be able to externalize some of the content when the project is in flash.   http://blogs.adobe.com/captivate/2010/08/flash-export-in-captivate-5.html  Hopefully all the scorm compliance will still be in place when doing this.
                              -doug lubey of louisiana
                              • 12. Re: Captivate 5 : "Loading..." Screen
                                Xeon64 Level 1
                                I have yet to get the preloaders to work. Both the Captivate and External Preloaders do not work right. I really wish I could get this figure out since my clients assume a slide is blank when an external swf is being loaded and the click to the next slide. If I prevent them from going to the next slide they think the module is broken.
                                I went to your site Doug and I am located in the same City as you and work in the same industry.
                                • 13. Re: Captivate 5 : "Loading..." Screen
                                  AICC Level 1
                                  very cool.  we may have to collaborate in person.  I will keep you up to date on my progress.
                                  I agree with you.....blank screens. pauses, delays and inaccurate progress meters are really bad (client thinks it is broken).   I am going to continue and try to get this working and may call adobe to see what options are available.
                                  Do you work in elearning?
                                  Our company caters to the power and petro-chem industry. (mainly).
                                  -doug
                                  • 14. Re: Captivate 5 : "Loading..." Screen
                                    Xeon64 Level 1
                                    My background was in graphic design but I have been doing elearning for about a year and a half because of my experience with Adobe applications. We are in the petro, ammonia, power, and various other industries. I probably have taken your training at the Safety Council whenever I have to go into a plant.
                                    My email address is jdonaldson@chemtechllc.com and will soon be jdonaldson@champ-tech.com
                                    • 15. Re: Captivate 5 : "Loading..." Screen
                                      AICC Level 1
                                      MORE RESEARCH COMPLETED.....STILLL DOES NOT WORK in LMS properly
                                      ..... any time adobe wants to chime in on this I would greatly appreciate it.
                                      Still have problems but made a little head way...
                                      The SWF/AS3 preloaders which come installed with captivate do not work out of the box..     These preloaders are shells which Adobe shipped with the product.  To get these preloaders to work,  you have to alter the action script using FLASH.  So this is what I did.  I altered the battery swf preloader and added code and textboxes into the process which showed me 4 things.
                                           1> little animation to show me how much content was loaded
                                           2> a label to tell me the actual percentage of content which was loaded
                                           3> a label to tell me how much Kb was loaded out of the total Kb.
                                           4> What percentage of content needs to be loaded before the movie starts playing.
                                      So now I at least have an accurate preloader which works.
                                      I attached this CUSTOMIZED preloader to the captivate project (under publish settings) and attempted to run a couple proof of concepts.
                                      Concept #1>  no reporting for the LMS....straight HTML on the web server   (no questions)
                                      Concept #1 RESULT>  preloader works perfectly...course starts perfectly  (worked perfectly at 20%, 50% and 80%)
                                      Concept #2> use SCORM 2004 reporting and publishe the content to the LMS web site.(no questions)
                                      Concept #2 RESULT 20% (publish settings were set to be 20%)>
                                           preloaded 20%; screen went blank for at least 15 seconds;  loading... screen appeared for at least 1 minute   (NOT GOOD !!!!)
                                      Concept #2 RESULT 50% (publish settings were set to be 50%)>
                                           preloaded 33%; loading... screen appeared for at least 1 minute  (NOT GOOD !!!!)
                                           WHY DID THE PRELOADER DISAPPEAR AFTER 33%...i setup the course for 50%
                                      Concept #2 RESULT 80% (publish settings were set to be 80%)>
                                           preloaded 33%; loading... screen appeared for at least 1 -2 minutes (NOT GOOD !!!!)
                                           WHY DID THE PRELOADER DISAPPEAR AFTER 33%...i setup the course for 80%
                                      MY QUESTIONS ARE THIS??
                                           1> what is this blank screen?
                                           2> why does the captivate course go into a loading mode for 1 minute or more?
                                      SUMMARY:
                                           I set my course to start after a specific percentage and I expect it to start after that.   Even if it does not start
                                           I would like the preloader to continue to be shown to the customer until the course can "REALLY" start.
                                      Doug Lubey of Louisiana
                                      • 16. Re: Captivate 5 : "Loading..." Screen
                                        AICC Level 1
                                        OK...i believe I found the magic checkbox
                                        TO ADOBE:
                                        Where is the documentation of your accepted business practices
                                        with respect to your publishing settings.
                                        SUMMARY:
                                        How to ensure you do not get a blank box nor have the loading screen
                                        show up for more than a second or two.
                                        THE MAGIC NUMBER IS PRELOAD 33.4%  (or 1/3 of the course)
                                        ....Do not go below 34% for preloading or you will get a blank screen.
                                        RULE #1> AUTO-PLAY (captivate will always think it needs to start @ 33%)
                                        If you have the course setup to AUTO-PLAY you must use 34% for preloading...
                                        The "loading ..." screen will appear for a couple seconds and then your course
                                        will start playing... To note; under some circumstance the audio would
                                        not play on the first slide. TO FIX THIS... insert a "title screen" w/o audio on the first
                                        slide.
                                        RULE #2> ****DO NOT USE AUTO-PLAY ****
                                        If you use auto-play...your preloader will always disappear after 33.3%....If you use
                                        a setting lower than 34%...you will get  a blank screen.  SO TURN AUTO-PLAY OFF
                                        and also set your preloading percent higher than 34%.
                                             I TESTED 34%...and the loading screen only appear for 3-4 seconds...it was commmunicating to the LMS
                                             I TESTED 42%...and the loading screen only appear for 1-2 seconds...it was commmunicating to the LMS
                                             I TESTED 51%...and the loading screen only appear for 1-2 seconds...it was commmunicating to the LMS
                                        NOTICE: none of these settings had question banks in them....this will be my next tests...
                                        OTHER THINGS I OBSERVED:
                                        The playbar will always appear after 33.3% of the course is loaded.  And check this out....The playbar is enabled once it is loaded  (SO YOUR CUSTOMERS will be able to click on the menu items)......once the click on the menu items and your preloader is setup to be higher than 34% the dreaded "loading screen" appears and your informative "Preloader" goes away.   ADOBE SHOULD OF DISABLED THE MENU BAR UNTIL...THE percent preloaded matches what I setup in the publish settings.
                                        Search Engine reference:
                                        ADOBE CAPTIVATE 5 preloader
                                        captivate five preloading
                                        how to adjust the preloader in captivate
                                        how to make the preloading of a trianing course using captivate 5 to work
                                        captivate 5 preloader does not work
                                        captivate 5 preloaders do not work they have to be modified using flash
                                        preloading captivate training courses do not work in a LMS (learning management system)
                                        www.douglubey.com
                                        • 17. Re: Captivate 5 : "Loading..." Screen
                                          edlearner Level 1
                                          Has anyone figured this out yet?
                                          • 18. Re: Captivate 5 : "Loading..." Screen
                                            RodWard Adobe Community Professional & MVP
                                            Under what specific circumstances are you seeing this endless loading screen Ed?
                                            • 19. Re: Captivate 5 : "Loading..." Screen
                                              edlearner Level 1
                                              Hi Rod! My loading screen works fine and reaches an end when the course is loaded. However, the problem is that I have a specific preloader selected to replace the gray "Loading..." screen but it does not show. Any idea why this happens? By the way, I am using Captivate 5.
                                              • 20. Re: Captivate 5 : "Loading..." Screen
                                                Ed.  Are you viewing this content via an LMS?
                                                • 21. Re: Captivate 5 : "Loading..." Screen
                                                  edlearner Level 1
                                                  Rod, my course is published  as SCORM 1.2 intended for viewing on an LMS (Sumtotal). I thought it was something my LMS was doing but this happens even when I test the published course on my desktop.
                                                  • 22. Re: Captivate 5 : "Loading..." Screen
                                                    Try turning off Resume Data by going into LMS Customization Settings and checking the box to Never Send Resume Data.
                                                    Then make a slight change to the Project Title in the Publish dialog and republish the module to a location on your hard drive.
                                                    Now test again to see if the Loading Screen disappears.
                                                    • 23. Re: Captivate 5 : "Loading..." Screen
                                                      edlearner Level 1
                                                      I tried both checking and unchecking the "Never Send Resume Data" but unfortunately I still get the dreaded gray loading screen upon viewing the course. Any other ideas?
                                                      • 24. Re: Captivate 5 : "Loading..." Screen
                                                        TheFlasher_net Level 1
                                                        That screen is the LMS Init Movie. If you commented the line that shows it in your CaptivateMaintimeline.as it should not appear anymore. If you don't know how to do that, in the following article you will be able to download the CaptivateMaintime file already modified:
                                                        http://www.theflasher.net/2011/11/09/lms-loading-screen-in-captivate-5/
                                                        • 25. Re: Captivate 5 : "Loading..." Screen
                                                          Ed:  What version of Captivate 5x are you on?  What is the precise minor version number and build?
                                                          I'm asking because I was under the impression that this Loading screen issue had been resolved in one of the recent Captivate 5 updates.
                                                          • 26. Re: Captivate 5 : "Loading..." Screen
                                                            edlearner Level 1
                                                            Thanks Flasher, but I tried commenting out that line and it did not work when I tested it on my desktop. I can see my custom preloader for a millisecond, then the dreaded gray loader appears.
                                                            Rod, The Captivate version I am using is: 5.0.1.631
                                                            • 27. Re: Captivate 5 : "Loading..." Screen
                                                              OK.  That's NOT the latest version.
                                                              I have 5.0.2.630
                                                              You may need to update your Captivate 5 version.
                                                              Try going to Help > Updates and see if it will let you download and install an update.
                                                              • 28. Re: Captivate 5 : "Loading..." Screen
        I know it is a stupid question but did you close Captivate completely and published your project again before testing?
        RodWard, I've got Captivate 5.5 up to date and it is still showing that screen if I uncomment that line :S
        • 29. Re: Captivate 5 : "Loading..." Screen
        edlearner Level 1
        Flasher ... your question is not stupid, in fact, that was something I did not think of doing (restarting Captivate). It is now working as intended showing the preloader of my choice. Thank you Flasher!
        Rod, thank you as well! Your help is also deeply appreciated!
        Another day of learning!!
        ~ edlearner
        • 30. Re: Captivate 5 : "Loading..." Screen
        My understanding of the Loading... screen is that it was related to the published project trying to locate the LMS SCORM API and would sometimes continue to appear if it was having trouble doing so.
        The now infamous "Endless Loading Screen" issue was usually related to the course module being set to use Resume Data LMS bookmarking, which works sometimes and at other times seems to get confusing for either the LMS or the course module.  Turning off LMS bookmarking would often resolve the issue.  That's why I was trying to see if something similar would work in this case.
        • 31. Re: Captivate 5 : "Loading..." Screen
        juliewales Level 1
        Sorry I'm confused, after I install the
        How do I install it or run it etc.
        I don't know if this will fix my issue as I'm not getting the grey screen at the beginning of my project.  I have on my 3rd slide a menu and if I click on any of the last two options on that menu I'm directed to the grey screen, my preloader doesn't work and when the movie starts moving again it skips the next slide and opens the one after that.
        I'm confused.
        Cheers
        Julie
        • 32. Re: Captivate 5 : "Loading..." Screen
        Once you've placed the patched .as file in the required folder you don't have to do anything other than republish your project/s.  Captivate uses this internal file when creating the published output.
        Julie, your last post seems to indicate that you are using a menu slide in one of your initial modules to load other modules in the course. Is that correct?  Or is this menu just pointing to other slides inside the SAME module?
        Also, where is this course being delivered from?  Are you running off a LAN or a web server, LMS or no LMS?
        • 33. Re: Captivate 5 : "Loading..." Screen
        juliewales Level 1
        Hi, thanks for the reply
        I have a menu slide that points to other slides within the same module.  Therefore the last 2 menu options are at the end of the module, hence my problem with loading times.  With regards to viewing the module, I am only previewing and publishing and viewing with IE.
        Any help you can provide as I can't get the preloader to work at all.
        • 34. Re: Captivate 5 : "Loading..." Screen
        I think your issue might be due to the fact that when your menu item jumps to a slide location near the end of the module it has to first render all of the slides in between first. So while it does that you are just seeing a blank screen.
        • 35. Re: Captivate 5 : "Loading..." Screen
        juliewales Level 1
        that's exactly it, is there anything I can do?  Also I still can't get the preloader to appear?
        • 36. Re: Captivate 5 : "Loading..." Screen
        Regarding your preloaded not working: Are you testing this from a web server or on a LAN drive?
        If the latter, you will find that preload ears do not work on LANs.
        • 37. Re: Captivate 5 : "Loading..." Screen
        juliewales Level 1
        Hi
        I am working on LAN drive.  My IT depart are just going to publish this on to a web server just now so that I can test this out.
        I tried to fix the problem by creating different modules from the different menu options as this would solve the loading issue.  However when trying to open a module from within a module I'm getting an error.  Is this because I'm working on a LAN drive?
        • 38. Re: Captivate 5 : "Loading..." Screen
        Could be.  Calling another module outside of the Captivate module when running off a LAN or hard drive would require you to have that folder location set up as a trusted location in your Flash Global Security settings.
        • 39. Re: Captivate 5 : "Loading..." Screen
        juliewales Level 1
        Hi there
        My IT department has put my module onto the web server and the preloader still isn't working, any ideas?  They were having problems publishing an .exe file so the module is now in a .swf file format.
        could this be making a difference.
        any further help would be much appreciated.
        Julie
        1 2 Previous Next
