1 Reply Latest reply on Sep 1, 2010 3:59 AM by rootsounds
    Drawing TrendLines in Line Chart
    Sen Imagines
      I am using a Line Chart in one of my projects.
      I use a HTTPService to fetch XML Data to feed the chart.
      <mx:HTTPService id="myServ" url="ChartData.xml" result="myResultHandler(event)"/>
      I draw two trend lines over the chart based on the max & min values for a specified node in the XML data
      <nodes>
          <node month="Jan-10">
             <expenses>20</expenses>
          </node>
          <node month="Feb-10">
             <expenses>30</expenses>
          </node>
          <node month="Mar-10">
              <expenses>80</expenses>
          </node>
          </node>
      </nodes>
      I use the expense node in determining the max & min value for the chart.
      I determine the max & min values & draw the lines in the result handler function:
      If i use result Format = "e4x", I am able to iterate the data as XML List Collection, but when I get the data as ActionScript objects, I am not able to iterate the XML data.
      public function drawLine(event:Event):void
           myChartCanvas.clear();
           myChartCanvas.lineStyle(2, 0x000000, 1);
           myChartCanvas.moveTo('Jan-10', 50);
           myChartCanvas.lineTo('Aug-10', 70);
      How can i iterate the nodes in AS3 object format to find the max & min nodes & draw the trend lines ?
      - Sen
