7 Replies Latest reply on Aug 31, 2010 3:57 PM by suku511
    Type Coercion Error
    suku511 Level 1
      Hi all,
      I am getting this error
      TypeError: Error #1034: Type Coercion failed: cannot convert flash.events::Event@cd1e589 to spark.events.IndexChangeEvent.
      at spark.accessibility::ListBaseAccImpl/eventHandler()[E:\dev\4.x\frameworks\projects\spark\ src\spark\accessibility\ListBaseAccImpl.as:402]
      I havent used any events except result event. I was trying to read an rss feed in flex 4 Can anyone help me out in figuring it out.
      Thanks in advance,
        • 1. Re: Type Coercion Error
          IMRAN R Level 1
          Can you show some part of your mxml?
          • 2. Re: Type Coercion Error
            rootsounds Level 4
            Whatever Spark list control you are using is throwing the error. Beyond that I haven't a clue without seeing some of your code.
            • 3. Re: Type Coercion Error
              suku511 Level 1
              Here is the code where list component is
                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="httpService.send()">
              <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
              <s:HTTPService id="httpService"
                 url="http://feeds.feedburner.com/mnt/healthnews"
                 result="onResult( event )" />
              </fx:Declarations>
              <fx:Script>
              <![CDATA[
              import flash.net.navigateToURL;
              import mx.collections.ArrayCollection;
              import mx.controls.Alert;
              import mx.rpc.events.FaultEvent;
              import mx.rpc.events.ResultEvent;
              import mx.utils.ObjectUtil;
              [Bindable]
              private var loading : Boolean = true;
              [Bindable]
              private var rssCollection : ArrayCollection = new ArrayCollection;
              private function onResult( event : ResultEvent ) : void
              var xy:ArrayCollection = event.result.rss.channel.item as ArrayCollection;
              list.dataProvider = xy;
              loading = false;
              private function onFault( event : FaultEvent ) : void
              Alert.show( ObjectUtil.toString( event.fault ), "Service Error" );
              loading = false;
              </fx:Script>
              <s:List width="100%"
              height="100%"
              id="list"
              itemRenderer="rssListRenderer"
              </s:Application>
              here is the item renderer code,_____________________________
              <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
              autoDrawBackground="true" >
              <s:layout>
              <s:VerticalLayout>
              </s:VerticalLayout>
              </s:layout>
              <s:Label text="{data.title}"
              width="100%"
              fontWeight="bold"
              fontSize="14" />
              <mx:Text
              color="#333333"
              id="description"
              htmlText="{ data.description }"
              width="{ width }"
              </s:ItemRenderer>
              • 4. Re: Type Coercion Error
                IMRAN R Level 1
                Error you mentioned that is raising only when you debug code? and it works fine
                if you directly run it.
                --Imran
                • 5. Re: Type Coercion Error
                  suku511 Level 1
                  for me even if I run with out debugging also I am getting that error. Please let me know how to overcome this.
                  • 6. Re: Type Coercion Error
                    Flex harUI Adobe Employee
                    That is a known issue.  If you don't need accessibility, turn it off.  There
                    should be a bug filed already that might have other workarounds.
                    • 7. Re: Type Coercion Error
                      suku511 Level 1
                      Thanks for the info. It works when accessibility is disabled.
