3 Replies Latest reply on Aug 31, 2010 11:58 AM by kglad
    How to use Movie Clips in arrays?
    Graham vdR Level 1
      Hi there
      I'm trying to learn how to use arrays. Specifically, I'm trying to use an array to control a set of movie clips ("box1" - "box8") contained within a parent movie clip ("boxes"). I've looked at the help pages and tried to apply what I learnt to my situation. Below is my code, but I'm not sure if I'm completely missing the mark. There seems to be a problem with how I'm trying to address the elements of the array in my if/else statement.
      Any advice?
      (I'm using AS2 in CS3.)
      var mouseListener:Object = new Object();
      var scale:Number;
      var scaleBig:Number = 200;
      var scaleSmall:Number = 100;
      var boxArray:Array = [boxes.box1, boxes.box2, boxes.box3, boxes.box4, boxes.box5, boxes.box6, boxes.box7, boxes.box8];
      boxes.onRollOver = function(){
          Mouse.addListener(mouseListener);
      boxes.onRollOut = function(){
          Mouse.removeListener(mouseListener);
      mouseListener.onMouseMove = function(){
          for(var box:String in boxArray){
              scale = (scaleBig - (Math.abs(_xmouse - [box]._x)));
              if(scale > scaleSmall){
                  [box]._xscale = scale;
              }else{
                  [box]._xscale = scaleSmall;
        • 1. Re: How to use Movie Clips in arrays?
          use:
          var scale:Number;
                  scale = (scaleBig - (Math.abs(_xmouse - boxArray[box]._x)));
                      boxArray[box]._xscale = scale;
                  }else{
                      boxArray[box]._xscale = scaleSmall;
          • 2. Re: How to use Movie Clips in arrays?
            Graham vdR Level 1
            Ah! I need to tweak my values, but the principle seems to be working now. I hoped it was just a small syntax mistake on my part, so I'm relieved to see that it was indeed an easy fix. Thanks very much!
            • 3. Re: How to use Movie Clips in arrays?
              you're welcome.
