6 Replies Latest reply on Sep 1, 2010 11:52 AM by Vie Bone
    Create RichEditableText with actionscript
    Vie Bone
      Hello all!
      i am trying to create a text element that allow me to insert or modify the text content.
      I am not using mxml, I need to create it with actionscript.
      The code that I'm using is:
      var textField:RichEditableText;
      private function displayText():void
           textField  = new RichEditableText();
           addChild(textField);
      private function insertText(t:String):void
           var tf:TextFlow = new TextFlow();
           var paragraph1:ParagraphElement = new ParagraphElement();
           var span1:SpanElement = new SpanElement();
           span1.text = t;
           paragraph1.addChild(span1);
           tf.addChild(paragraph1);
           textField.textFlow = tf;
      insertText("hello world");
      This code doesn't work
      Any Ideas?????
      Thanks a lot.
        • 1. Re: Create RichEditableText with actionscript
          Flex harUI Adobe Employee
          DO you get an error?
          • 2. Re: Create RichEditableText with actionscript
            Vie Bone Level 1
            No, I don't get any error.
            Working on my problem I realize that the problem is that I'm working in a .as file, not in a mxml file and in the class I have to use addChild an not addElement.
            If I do the same in a mxml file and add my new RichEditableText with the addElement function it works perfect.
            Do you know why??? I would like to set up the RichEditableText in a class.
            Thanks.
            • 3. Re: Create RichEditableText with actionscript
              Is your class an AS component?  What does it extend?  It has to follow the
              rules to being a custom Flex AS component.
              • 4. Re: Create RichEditableText with actionscript
                Vie Bone Level 1
                hi thanks!
                I don't know if I am doing it in the correct way, if you don't mind I am puting my code bellow:
                - MXML FILE:
                <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:mx="library://ns.adobe.com/flex/mx" width="100%"
                creationComplete="loadXML()">
                <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
                <fx:Script>
                <![CDATA[
                import assets.MenuItemSelectedEvent;
                import assets.Moogaloop2;
                import assets.ProjectInfo;
                import mx.collections.ArrayCollection;
                import mx.controls.Alert;
                import mx.controls.Image;
                import mx.core.UIComponent;
                import mx.flash.UIMovieClip;
                import spark.components.RichEditableText;
                private var xmlData:XML;
                [Bindable]
                private var _w:Number = 640;
                [Bindable]
                private var _h:Number = 360;
                [Bindable]
                private var _title:String;
                private var elementsArr:Array = new Array();
                private var projectInfoWrapper:UIComponent;
                private var myText:RichEditableText;
                protected function loadXML():void
                var urlrequest:URLRequest = new URLRequest("../data/categories.xml");
                var urlloader:URLLoader = new URLLoader();
                urlloader.addEventListener(Event.COMPLETE, urlLoaderComplete);
                urlloader.load(urlrequest);
                protected function urlLoaderComplete(evt:Event):void
                xmlData = new XML(evt.target.data);
                public function loadProject(_category:Number, _project:Number, w:Number):void
                cleanElements();
                _title = xmlData.category[_category].@name;
                _title +=  " > " + xmlData.category[_category].project[_project].@name;
                projectInfoWrapper = new UIComponent();
                projectInfoWrapper.visible = false;
                var projectInfo:ProjectInfo = new ProjectInfo(_w,_h);
                projectInfoWrapper.addChild(projectInfo);
                var projectIMG:XMLList = xmlData.category[_category].project[_project].img;
                var projectVID:XMLList = xmlData.category[_category].project[_project].vid;
                //_w = w;
                if(projectIMG.length() > 0)
                addPhotos(projectIMG);
                if(projectVID.length() > 0)
                addVideos(projectVID);
                this.addElement(projectInfoWrapper);
                myText = new RichEditableText();
                myText.text = "jon is a good man asdf asdf asdf asdf asdf asdfas df asdfa dsfasf fd";
                myText.setStyle("color","white");
                this.addElement(myText);
                projectInfoWrapper.y = imgScroller.y;
                myText.y = projectInfoWrapper.y;
                protected function addPhotos(photos:XMLList):void
                for(var x:Number=0; x<photos.length(); x++)
                var img:Image = new Image();
                img.source = "../"+photos[x].@url;
                img.id = String(x);
                imgContainer.addElement(img);
                elementsArr.push(img);
                protected function addVideos(videos:XMLList):void
                for(var x:Number=0; x<videos.length(); x++)
                var id:String = videos[x].@id;
                var title:String = videos[x].@title;
                var vid:Moogaloop2 = new Moogaloop2(id,title);
                var playerSize:Array = vid.getPlayerSize();
                vid.name = id;
                var vidContainer:UIComponent = new UIComponent();
                vidContainer.width = 640;
                vidContainer.height = 360;
                vid.x = vidContainer.width / 2 - playerSize[0] / 2;
                vidContainer.addChild(vid);
                imgContainer.addElement(vidContainer);
                elementsArr.push(vid);
                protected function cleanElements():void
                if(elementsArr.length > 0)
                for(var x:Number = 0; x < elementsArr.length; x++)
                if(getQualifiedClassName(elementsArr[x]) == "assets::Moogaloop2")
                elementsArr[x].externalCloseAction();
                imgContainer.removeAllElements();
                elementsArr = new Array();
                protected function showHideInfo():void
                if(projectInfoWrapper.visible)
                }else
                projectInfoWrapper.visible = true;
                </fx:Script>
                <s:SkinnableContainer id="allContainer">
                <s:layout>
                <s:VerticalLayout />
                </s:layout>
                <s:SkinnableContainer>
                <s:VGroup width="{_w}" horizontalAlign="right">
                <s:BitmapImage source="@Embed('skins/assets/socialmedia_buttons.jpg')"/>
                <s:HGroup horizontalAlign="left" width="100%">
                <s:Label id="title" text="{_title}" color="#FFFFFF" width="100%"/>
                <s:Button label="Project Info" click="showHideInfo()"/>
                </s:HGroup>
                </s:VGroup>
                </s:SkinnableContainer>
                <s:Scroller id="imgScroller" width="{_w}" height="380" verticalScrollPolicy="off">
                <s:HGroup id="imgContainer">
                </s:HGroup>
                </s:Scroller>
                </s:Group>
                - THE ACTIONSCRIPT CLASS(I chenged the code but this is the class in where i was creating the RichEditableText):
                package assets
                import flash.display.Sprite;
                import flash.text.TextField;
                import flash.text.TextFormat;
                import flash.text.TextFormatAlign;
                import flashx.textLayout.conversion.ITextImporter;
                import flashx.textLayout.conversion.TextConverter;
                import flashx.textLayout.edit.EditManager;
                import flashx.textLayout.elements.FlowElement;
                import flashx.textLayout.elements.ParagraphElement;
                import flashx.textLayout.elements.SpanElement;
                import flashx.textLayout.elements.TextFlow;
                import mx.controls.Text;
                import mx.events.FlexEvent;
                import spark.utils.TextFlowUtil;
                public class ProjectInfo extends Sprite
                private var square:Sprite;
                private var w:Number;
                private var h:Number;
                private var textField:RichEditableText;
                private var myEdit:EditManager;
                private var _textFlow:TextFlow;
                private var importer:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_LAYOUT_FORMAT);
                public function ProjectInfo(_w:Number,_h:Number)
                w = _w;
                h = _h;
                textField.width = _w;
                textField.height = _h;
                textField.text = "ya ya ya ya ayasf asdf asdf asdf asdf asdf";
                //textField.editable = true;
                //textField.wordWrap = true;
                addChild(simple_shape());
                public function simple_shape():Sprite
                square = new Sprite();
                addChild(square);
                square.graphics.lineStyle(1,0xffffff);
                square.graphics.beginFill(0x000000);
                square.graphics.drawRect(0,0,w,h);
                square.graphics.endFill();
                square.alpha = 0.7;
                return square;
                Thanks a lot.
                • 5. Re: Create RichEditableText with actionscript
                  Plain Sprites cannot parent UIComponents.  The parent must also extend
                  UIComponent
                  • 6. Re: Create RichEditableText with actionscript
                    Vie Bone Level 1
                    Ahhhh my friend, what a silly think, sorry and thanks a lot!!!!!
