0 Replies Latest reply on Sep 1, 2010 1:30 AM by picolo74
    Convertion from pdf is really bad
    picolo74 Level 1
      Hi !
      First, i m pretty ignorant in making pdf form...
      I need to make an interractive form from a pdf file (25 pages) given by a friend.
      he gave me 2 version of the file, a 'normal' pdf and one in form version (without any calcul or interractivity).
      (but it lacks 3 fonts)
      I tried to make it with Acrobat :
      with both version of the file,
      i c'ant find all the events i need in 'Action' tab when i try to add some code on a textBox like 'change', 'docReady'...
      But the way i can make the form is really good. In fact i only need to add textbox, radiobutton... i don't want to edit text.
      With LiveCycle i create a new document from the pdf and i select interractive. i need to change tooltip, visibility of objects..., wich can t be done with non interractive form (if i understand correctly ?).
      my problem is that the converted file is really bad, the convertion log contains a lot of errors.
      and it will take me a lot of time to correct, adapt it, plus, images are pixelised ( why ??).
      My questons :
      Can i make interractive form without converting the document ? like with Acrobat or non interractive forms ?
      Is there a way to have a source file instead of the pdf ? wich contains images, fields... so there will be no convertion.
      Thanx for reading
