3 Replies Latest reply on Sep 3, 2010 11:24 PM by Norman Be
    Really Basic Script question
    Wayne_2010
      I found a script on this site which adds the filename to my image. However it is NOT an Adobe JavaScipt file but rather a JScript Script File.  I know that the Adobe JavaScript files can be copied to the Script folder to utilize in Photoshop.  But what would be the required steps involved in order to utilize this 'JScript Script File' type of file in CS3 or CS4?  I tried to search for something on this issue results always came up zero. I apologize for this really newbee type question..... -Wayne
        • 1. Re: Really Basic Script question
          Are you sure its not a Photoshop Script.  If you found it on this site it is most likely a Photoshop Script.  Photoshop script have a file extension of .js or .jsx many .js Photoshop Scripts can be renamed to .jsx and still work.  Years ago there were only .js files then Adobe came up with .jsx for files that only use Photoshop supported function.  Photoshop Scripts can be run from any folder on one's machine.  I keep mine in "C:\Program Files\Adobe\Adobe Photoshop Scripts\My Scripts" and I place a shortcut link to "C:\Program Files\Adobe\Adobe Photoshop Scripts\" into My currently installed versions of Photoshop  folder "Photoshop version\presets\script" All installed versions of Photoshop get my scripts from a single location which stays put and doesn't move with each version of Photoshop.  This is very important for I use many of my scripts in Photoshop Actions.  If a script's locations changes with each Photoshop release the actions that use them would need to be recorded for each version of Photoshop and kept in a location for that version of Photoshop. I prefer to keep one copy of my actions in a single location that does not move. But of course these have to be loaded into each version of Photoshop.  Still you better off keeping extensions you add to Photoshop outside of an Adobe folder. "C:\Program Files\Adobe\Adobe Photoshop Scripts\" is my creation not Adobe's.  However not all thing can be install outside of Adobe's folders some third party developers foolishly hard code in them code the require themselves to be in Adobe's tree.
          • 2. Re: Really Basic Script question
            Muppet Mark-QAl63s Level 4
            You may also want to open the ESTK (ExtendScript Toolkit) should be installed on your machine somewhere (utilities folder on the mac). Then navigate to your script.js file and try to open it. The author of the script in question may have put some commented notes on its usage in there etc… Might give us a better idea of the scripts content… and how best to use it…
            • 3. Re: Really Basic Script question
              Norman Be
              Make a Folder in your C drive and Name it PS Scripts.
              Open Note Pad and copy the scipt into Note Pad. Now, and this is important change the Text Document on the lower right corner to All Files.
              For File Name type the Name toy want to give to the script and right after it .js (dot js) no spaces and save it to the folder you just made.
              Invoke the script from File--Scripts=Brows to the folder and the script.
              I put my scripts into the C drive for the same reason JJMack does.
