4 Replies Latest reply on Sep 3, 2010 7:17 AM by miguel8312
    update progress bar while looping
    miguel8312 Level 3
      I finally got it through my thick skull flex is single threaded. GOT IT!!! however there has got to be a way to update the interface while in a loop. i have the following code that does not seem to work. I know there is got to be a  better way but i cant seem to pinpoint it out.
      Can anyone offer an example or any ideas. I have tried doing the following and it just does not work...
      <mx:Application
       xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
      <mx:Script>
                <![CDATA[
      import flash.events.TimerEvent;
      import flash.utils.Timer;
      import flash.utils.setTimeout;
      private var delay:Number = 0; // delay before calling myDelayedFunction
      import mx.controls.Alert;
      private var fr:FileReference;
      Bindable]
      public var data1:ByteArray;
      public var timer:Timer = new Timer( 10000 );
      public var count:Number = 0;
      public function init():void
      this.timer.addEventListener( TimerEvent.TIMER, updateProgress );
      this.timer.start();
      protected function updateProgress(value:int):void
                          count++;
                          progress2.setProgress( (value % 10), 100 );
                          progress2.label = (value % 10) +
      "%";                    progress2.invalidateDisplayList();
      //File types which we want the user to open
      private static const FILE_TYPES:Array = [new FileFilter("Text File", "*.csv;*.text")];
      //called when the user clicks the load file button
      private function onLoadFileClick():void
      // fr.addEventListener(ProgressEvent.PROGRESS, onProgress);
      //create the FileReference instance
                          fr =
      new FileReference();
      //listen for when they select a file
                          fr.addEventListener(Event.SELECT, onFileSelect);
      //listen for when then cancel out of the browse dialog
                          fr.addEventListener(Event.CANCEL,onCancel);
      //open a native browse dialog that filters for text files
                          fr.browse(FILE_TYPES);
      /************ Browse Event Handlers **************/
      //called when the user selects a file from the browse dialog
      private function onFileSelect(e:Event):void
      //listen for when the file has loaded
                          fr.addEventListener(Event.COMPLETE, onLoadComplete);
      // listen forprogress
      //listen for any errors reading the file
                          fr.addEventListener(IOErrorEvent.IO_ERROR, onLoadError);
      //load the content of the file
                          fr.load();
      // listen to write to arrays
                          fr.addEventListener(Event.COMPLETE, eventComplete);
      private function onLoadComplete(e:Event):void
      //get the data from the file as a ByteArray
      //myData = new ArrayCollection();
                          data1 = fr.data;
      //outputField.text = data1.readUTFBytes(data1.bytesAvailable);
      //called if an error occurs while loading the file contents
      private function onLoadError(e:IOErrorEvent):void
      trace("Error loading file : " + e.text);
      private function onProgress(event:ProgressEvent):void{
      //          pbProgress.visible = true;
      var bloaded:uint = new uint;
      var btotal:uint = new uint;
                          bloaded = event.bytesLoaded;
                          btotal = event.bytesTotal;
      private function onCancel(e:Event):void
      trace("File Browse Canceled");
                          fr =
      null;               }
      public function eventComplete(event:Event):void{
      var record:Array = new Array();
      var obj:Object;
      var fields:Array = new Array();
      var result:String = new String(fr.data);                    record = result.split(
      "\r\n");
      for ( var i:int = 0; i<record.length; i++)// ++ stands for increment
                               obj =
      new Object();                         fields = record[i].split(
      ",");// separate each field by comma.
                               obj.col1  =  fields[0];
      trace(obj.col1);
                               count=i;
                               updateProgress(count)
      //setTimeout(updateProgress,delay);
      //callLater(updateProgress);
      </mx:Script>
      <mx:ProgressBar id="progress2" minimum="100" maximum="100" mode="manual"                         label="
      0%" labelPlacement="bottom">
      </mx:ProgressBar>
      <mx:Button label="clickme" click="onLoadFileClick()"/>
      </mx:Application>
        • 1. Re: update progress bar while looping
          Flex harUI Adobe Employee
          Try updateAfterEvent
          • 2. Re: update progress bar while looping
            miguel8312 Level 3
            do you have any sample code to show me how to use this.???
            I was able to acomplish this by litterally breaking everytime it loops. look below i dont know if this is the best way to do it. but it works for me.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
                  <mx:Script>
                        <![CDATA[
                              private var delay:Number = 2000; // delay before calling myDelayedFunction
                              [Bindable]
                              public var timer:Timer = new Timer(10);
                                    this.timer.start();
                              protected function updateProgress(time:Event):void
                                    //count++;
                                    //progress2.setProgress( ((count/record.length% 10)),(record.length));
                                    progress2.setProgress(count,record.length)
                                    //progress2.setProgress( (count% 10), 100 );
                                    progress2.label = Math.round(count/record.length * 100).toString()+"%";
                                    timer.stop()
                                    resumeLoop();
                                    fr = new FileReference();
                                    fr.load();
                                    data1 = fr.data;
                                    fr = null;
                              public var recordPointer:int;
                              public var totalCount:int;
                              public var record:Array = new Array();
                              public var obj:Object;
                              public var fields:Array = new Array();
                              public var i:int;
                                    resumeLoop();
                              public function resumeLoop():void{
                                    record = result.split("\r\n");
                                    if (record.length == i) {done();}
                                    else{
                                    for ( i<record.length; i++;)// ++ stands for increment
                                          if (i == record.length){break};
                                          obj = new Object();
                                          fields = record[i].split(",");// separate each field by comma.
                                          trace(obj.col1);
                                          count=i;
                                          break;
                                    if (i == record.length){done()}
                                    else{
                                          this.timer.start();
                              public function done():void
                  </mx:Script>
                                          label="0%" labelPlacement="bottom">
                  </mx:ProgressBar>
            </mx:Application>
            • 3. Re: update progress bar while looping
              I'm not sure why you needed to stop and start.  Calling
              time.updateAfterEvent should have helped.
              • 4. Re: update progress bar while looping
                miguel8312 Level 3
                Flex harUI  im sure your right but i did not have any luck using updateafterevent. can
                you please put together a little example?  i really love to see how you would do
                it it using that method... hope to hear back from you im eager to learn and love to see how you
                would acomplish with one function as supposed to 3 functions like i did.
                Miguel
