16 Replies Latest reply: Sep 5, 2010 4:27 PM by Brit.b RSS
    How does one manage these new render setting for previews?
    Brit.b Community Member
      I placed 4 HD clips from a nested into a sequence 5800 x 768 to mimic 4 side by side monitors for a multi channel video.  Each clip cut from the sequence are at 1280x720 all sitting side by side. However when I rendered the previews, they came look all squished. However when I exported the frame it looks fine in Photoshop. (I changed the uploaded image to what it looks like in Premiere in Photoshop to demonstrate the appearance in Premiere.)
      I imagine that the distortion has to do with the sequence render setting which for some reason comes out to 1918 x 253...or the pixel aspect ratio? How does one manage these new render setting for previews so it looks normal in the monitor?
        • 1. Re: How does one manage these new render setting for previews?
          Harm Millaard CommunityMVP
          Why the strange dimensions? When you start with 1280 x 720 and you want to simulate 4 screens wide images, it apears much more logical to use a dimension of 4 x 1280 = 5120 by 720, while maintaining square pixels.
          • 2. Re: How does one manage these new render setting for previews?
            It seems that the pixel aspect ratio was the problem-going from 1.333 to square piles. My footage is all 1080i (x 1440). So I did a new sequence at 5120 by 720 (using the desktop editing mode) and when resizing the clips to fit the space between them was significant (image uploaded on this page.)Sequence 5120.Still001.jpg
            I also tried 3840 x720, and this worked fine...except it was not quite enough space for all the 4 clips. (1080: 720 is 1.5, and 1440 divided by 1.5 is 3840). What would the correct width be? It is just a bit over 3900, I think....This is quite a puzzle for my math challenged mind
            • 3. Re: How does one manage these new render setting for previews?
              When you start out with 1440 x 1080 HDV material with a PAR of 1.333 that means 1920 x 1080 with square pixels.
              Now for 4 simulated screens, that would mean 4 x 1920 = 7680 pixels wide and 1080 vertical with the same square pixels. If you go from there to the dimension you want, you should be OK.
              • 4. Re: How does one manage these new render setting for previews?
                I tried this format using square in the (desktop) sequence and it worked...until I closed and re-opened the video and it again appeared squished in the monitor when re-opened. Next I made another sequence with anamorphic pixels ratio (1.333) at 1440 (x4) -5760 x 1080, and this too looked fine. I then closed and re-opened and the previews disappeared. I re-rendered and it came out equally squished and distorted as the other times. I am totally perplexed now.
                Message was edited by: Brit.b
                • 5. Re: How does one manage these new render setting for previews?
                  The mystery continues. I simply cannot get the monitor to playback correctly with previews in the desktop sequence format in the program monitor. They continue to be distorted, as in the illustration in the first post. I checked the rendered preview files and individually they playback fine without distortion in the source monitor. However when checking the properties of the rendered preview files they are 1920x1080 even though the sequences setting for previews is 1920 by 360.
                  • 6. Re: How does one manage these new render setting for previews?
                    Powered by Design Community Member
                    Use G-Spot to take a screen capture of what the original footage is.
                    http://www.headbands.com/gspot/
                    Maybe your sequence is not matching.
                    Also what format are you trying to save your final version in ?
                    G
                    • 7. Re: How does one manage these new render setting for previews?
                      OK, I have new different, but related set of questions. I posted again, but it was deleted and was followed by a stern warning that my question was answered and not to post again by a “John Smith”. It was not answered.
                      My questions are now (I have reframed the problem as I discover new aspects):
                      Why would the video previews disappear from the project when reopening a file (but the preview still remains in the preview folder)?
                      Why when I redo the preview is it rendered in a completely different setting than Sequence video preview setting? The preview setting is for 1920 x270, but it renders at 1920 x1080 when I reopen the project after the original (in the correct 1920 x270 aspect ratio) preview fails to reload with the project?
                      I'm not sure what Powered by Design means by "matching sequence". The final version is to be 5120 x 720.
                      • 8. Re: How does one manage these new render setting for previews?
                        Ok as I spend my Sunday on this Sisyphus –like problem, I have found new strange angle. When I push “reset” on Sequence settings > video previews; Premier deletes the preview files, but it does re render correctly at the right aspect ratio. The problem is that when I close the project and then re open it, the preview disappears and I have to go through the whole rigmarole again. I have created several different files, in case the first one was corrupt, but the same thing happens to each new project.
                        • 9. Re: How does one manage these new render setting for previews?
                          I too am lost.
                          Dont know why it is squashing it after doing a render.
                          Also when I render the video goes SOFT.
                          Hard to tell with the screencap but the full screen preview in second monitor looks soft.
                          Before any rendering.
                          After rendering small WAB
                          Im not sure why the preview does not reload after closing the program then re-opening it.
                          It worked for me.  my previews reloaded after closing and re-opening.  Maybe you forgot to save.
                          As far as "matching sequence" I was saying that because in the first post you said footage of 1280x720 but in post 2 you said 1080i footage at 1440x1080 so I wanted to make sure what your footage really was so the correct setting for the sequence could be set.
                          My footage is HDV at 1440x1080i
                          Something is happening when you hit the ENTER key to render.  The footage is squished to 270 in the Program monitor.  Its correct on my second screen but off on the program monitor.
                          The problem seems that Premiere wont let me export anything over 1920x1080.
                          I have match sequence settings checked and you can see that I have my sequence set for 4 full HDV
                          Still playing around.  Anyone else with ideas.
                          GLenn
                          • 10. Re: How does one manage these new render setting for previews?
                            What is your final goal Brit ?
                            How are you going to play a file that is 7680x1080 ?
                            What format are you going to render to ?
                            Is your goal just to have 4 videos playing side by side or do you have a player with 4 monitors wide that can play it ?
                            This has been the first time trying to get 4 videos with those settings so I see where your running into problems.
                            You might be better off just creating a regular HDV sequence and scaling each clip down 50% and have one in each corner.
                            That way your final version will be 1920x1080 with square pixels.
                            Unless your goal is a DVD then your should stay with it interlaced.
                            isnt this fun.  lol
                            GLenn
                            • 11. Re: How does one manage these new render setting for previews?
                              It is squashing because the preview render comes in at 1920 x 1080 instead of the 1920 x270 setting that is in the "sequence setting> video previews" setting. The 1920 x 1080 preview rendering is squashed in the long 5760 x 1080 format.  If I press “reset”, then it come in at 1920 x270, which is the correct non-squashed aspect ratio, but it doesn’t return at that size when I  save> close then re open the same file. The render file just disappears and re rendering produces the 1920 x 1080 squashed preview. I have spent all day doing this with different variations and different files... all with the same result in this format (or with 7680 x 1080 with square pixels).  Also in another bizarre twist, if I nest another older project file in this project, the scratch disk returns to a different “same as project folder” drive (not the separate disk for previews that I set it to). It is just switching settings without warning.  This too is repeated with different files. It is very strange. It doesn’t happen with nesting other normal format files in normal format projects...just these particular settings.
                              • 12. Re: How does one manage these new render setting for previews?
                                “What is your final goal Brit ? Is your goal just to have 4 videos playing side by side or do you have a player with 4 monitors wide that can play it ?”
                                My goal is to edit 4 videos side by side- with 4 monitors.. It will be used for a Watchout"  system http://www.dataton.com/watchout for “E4C: celebrate electronic art. “This playback system can support WMV or a QuickTime files with H.264 codec”. They provided an After effects template, but I don’t use after effects.
                                I also would like to use this format for experimenting with 4 channels.
                                • 13. Re: How does one manage these new render setting for previews?
                                  So after watching the Watchout videos what I gather you want to do with Premiere is to be able to edit 4 nested HDV clips on a 7680x1080 timeline so you can cut them at the same time to see what each video will look like.  Making it look like one huge video.
                                  But your end goal is to export each one at 1920x1080 and let the Watchout software stitch them back together for the projectors.
                                  You dont really need a finished video of 7680x1080 right ?
                                  For me if I dont hit ENTER to make it render then I never have a problem of it resizing it.
                                  Is this what your trying to do ?
                                  GLenn
                                  • 14. Re: How does one manage these new render setting for previews?
                                    Either way, I thought that this format would be a great way to view on the monitor 4 channels at the same time. I may need to place them on a “normal” 1440 x 1080 sequence in a line, bringing them down to 25% scale to make it work in the end. I did just try that. I think it will work...but when I imported and nested the old file, the scratch disks changed from the original set up on a D drive back to the main hard drive so I had to change it agin. Otherwise it works fine...so I’ll go with this for now
                                    These are the instructions I was given.I attched a screen save of the AE file they asked me to use (They must be on vacation, because I have not been able to get hold of them). IAfter Effects 4 culture file.jpg don't know After Effects very well:
                                    “As you begin creating or adapting work for e4c, you may find an After Effects template developed for this system to be helpful. Attached you'll see a zipped file with two AE templates. There is some detailed information (below) from the artist that developed these for us. In addition, a few bits of information that might help you along are:
                                    ·        The "Watchout"  playback system can support WMV or a QuickTime files . We like .mov files with H.264 codec best!
                                    ·        The end resolution of the four screens is 5120 x 720 pixels (1280x720 each).
                                    ·        If works are four-channel, please provide a separate audio (aiff) file so it doesn't slow any one video down.”
                                    Thanks for your help!
                                    • 15. Re: How does one manage these new render setting for previews?
                                      I agree that starting with a standard HDV timeline and scaling it down to 25% does sound like the best answer.
                                      It seems like your starting to get it.
                                      I haven't tried to make videos for multiple monitors so this was new to me.   FUN
                                      Good luck:   GLenn
                                      • 16. Re: How does one manage these new render setting for previews?
                                        Yes it doesn't delete the preview files and replace them, so this will work until the bug is fixed.
