3 Replies Latest reply on Jul 27, 2007 1:58 PM by Newsgroup_User
    AIR Intrinsic Classes-Tried and Proven Approach to building AIR applications   in the Flash CS3 IDE
    Level 7
      Hi everyone,
      For all of you out there who would like to develop AIR applications
      from the Flash CS3 IDE but aren't sure how to get those pesky intrinsic
      classes working, I have a technique that you can work with to create
      your classes and make fully functional AIR applications.
      First of all, those solutions out there that list "intrinsic" functions
      in their class definitions won't work. That keyword has been taken out
      and simply won't work. The "native" keyword also doesn't work because
      Flash will reject it. The solution is to do dynamic name resolution at
      runtime to get all the classes you need.
      Here's a sample class that returns references to the "File",
      "FileStream", and "FileMode" classes:
      package com.adobe{
      import flash.utils.*;
      import flash.display.*;
      public class AIR extends MovieClip {
      public static function get File():Class {
      try {
      var classRef:*=getDefinitionByName('flash.filesystem.File');
      } catch (err:ReferenceError) {
      return (null);
      }//catch
      return (classRef);
      }//get File
      public static function get FileMode():Class {
      try {
      var classRef:*=getDefinitionByName('flash.filesystem.FileMode');
      return (null);
      }//catch
      return (classRef);
      }//get FileMode
      public static function get FileStream():Class {
      try {
      var classRef:*=getDefinitionByName('flash.filesystem.FileStream');
      return (null);
      }//catch
      return (classRef);
      }//get FileStream
      }//AIR class
      }//com.adobe package
      I've defined the package as com.adobe but you can call it whatever you
      like. You do, however, need to import "flash.utils.*" because this
      package contains the "getDefinitionByName" method. Here I'm also
      extending the MovieClip class so that I can use the extending class
      (shown next) as the main Document class in the Flash IDE. Again, this is
      entirely up to you. If you have another type of class that will extend
      this one, you can have this one extend Sprite, Math, or whatever else
      you need (or nothing if it's all the same to you).
      Now, in the extending class, the Document class of the FLA, here's the
      class that extends and uses it:
      package {
      import com.adobe.AIR;
      public class airtest extends AIR{
      public function airtest() {
      var field:TextField=new TextField();
      field.autoSize='left';
      this.addChild(field);
      field.text="Fileobject="+File;
      }//constructor
      }//airtest class
      }//package
      Here I'm just showing that the class actually exists but not doing much
      with it.
      If you run this in the Flash IDE, the text field will show "File
      object=null". This is because in the IDE, there really is no File
      object, it only exists when the SWF is running within the Integrated
      Runtime. However, when you run the SWF as an AIR application (using the
      adl.exe utility that comes with the SDK, for example), the text field
      will now show: "File object=[object File]". Using this reference, you
      can use all of the File methods directly (have a look here for all of
      them:
      http://livedocs.adobe.com/labs/flex/3/langref/flash/filesystem/File.html).
      For example, you can call:
      var appResource:File=File.applicationResourceDirectory;
      This particular method is static so you don't need an instance. If you
      do (such as when Flash tells you the property isn't static), simply
      create an instance like this:
      var fileInstace:File=new File();
      fileInstance.someMethod('abc'); //just an example...read the reference
      for actual function calls
      Because the getter function in the AIR class returns a Class reference,
      it allows you to perform all of these actions directly as though the
      File class is part of the built in class structure (which in the
      runtime, it is!).
      Using this technique, you can create references to literally *ALL* of
      the AIR classes and use them to build your AIR application. The beauty
      of this technique is its brevity. When you define the class reference,
      all of the methods and properties are automatically associated with it
      so you don't need reams of code to define each and every item.
      There's a bit more that can be done with this AIR class to make it
      friendlier and I'll be extending mine until all the AIR classes are
      available. If anyone's interested, feel free to drop me a line or drop
      by my site at http://www.baynewmedia.com where I'll be posting the
      completed class. I may also make it into a component if there's enough
      interest. To all of you who knew all this already, I hope I didn't waste
      your time.
      Happy coding,
      Patrick
