    2 Replies Latest reply on Sep 2, 2010 7:49 AM by beno12345
    Bitmap Alpha Problem
    beno12345 Level 1
      Hi;
      I'm trying to tweak a script I found online to work for my application.  The problem I am having is to make a certain part of the bitmap that is  created by code transparent...but only a certain part of it. The code  has the following:
      _fire = new BitmapData(865, 92, false, 0xffffff);
      Note
      the alpha flag must be set to false, which is the source of my problem,
      or nothing prints to screen at all. I need to make certain pixels
      transparent. _fire is added to the stage and then called thus:
      _fire.paletteMap(_grey, _grey.rect, ZERO_POINT, _redArray, _greenArray, _blueArray, _alphaArray);
      at the end of the script. The colors for the arrays are created thusly:
      private function _createPalette(idx:int):void {
      _redArray = [];
      _greenArray = [];
      _blueArray = [];
      _alphaArray = [];
      for (var i:int = 0; i < 256; i++) {
      var gp:int = new int();
      gp = _fireColor.getPixel(i, 0);
      if (gp < 1050112)
      _redArray.push(255);
      _alphaArray.push(255);
      } else {
      _redArray.push(gp);
      _alphaArray.push(0);
      _greenArray.push(0);
      _blueArray.push(0);
      I
      added that if clause to capture when the color is black because that's
      where I need to make it transparent. The problem is that where I need it
      to be transparent, it's blue (why blue I don't know). Is there any way
      to make it transparent? The entire code follows.
      TIA,
      George
      package {
      import flash.display.Bitmap;
      import flash.display.BitmapData;
      import flash.display.BlendMode;
      import flash.display.DisplayObject;
      import flash.display.Loader;
      import flash.display.LoaderInfo;
      import flash.display.Sprite;
      import flash.display.StageQuality;
      import flash.display.StageScaleMode;
      import flash.events.Event;
      import flash.events.MouseEvent;
      import flash.filters.ColorMatrixFilter;
      import flash.filters.ConvolutionFilter;
      import flash.geom.ColorTransform;
      import flash.geom.Point;
      import flash.system.LoaderContext;
      import flash.net.SharedObject;
      import flash.net.URLRequest;
      import flash.text.TextField;
      import flash.text.TextFieldAutoSize;
      import flash.text.TextFormat;
      [SWF(width=465, height=92, backgroundColor=0xffffff, frameRate=30)]
      public class Fire extends Sprite {
      private static const ZERO_POINT:Point = new Point();
      private var _fireColor:BitmapData;
      private var _currentFireColor:int;
      private var _canvas:Sprite;
      private var _grey:BitmapData;
      private var _spread:ConvolutionFilter;
      private var _cooling:BitmapData;
      private var _color:ColorMatrixFilter;
      private var _offset:Array;
      private var _fire:BitmapData;
      private var _redArray:Array;
      private var _zeroArray:Array;
      private var _greenArray:Array;
      private var _blueArray:Array;
      private var _alphaArray:Array;
      public function Fire() {
      //            stage.scaleMode = StageScaleMode.NO_SCALE;
      //            stage.quality = StageQuality.LOW;
      var loader:Loader = new Loader();
      loader.contentLoaderInfo.addEventListener(Event.CO  MPLETE, _onLoaded);
      loader.load(new URLRequest('images/fire-color.png'), new LoaderContext(true));
      private function _onLoaded(e:Event):void {
      _fireColor = Bitmap(LoaderInfo(e.target).loader.content).bitmap  Data;
      _canvas = new Sprite();
      _canvas.graphics.beginFill(0xffffff, 0);
      _canvas.graphics.drawRect(0, 0, 865, 465);
      _canvas.graphics.endFill();
      _canvas.addChild(_createEmitter());
      _grey = new BitmapData(865, 465, false, 0xffffff);
      _spread = new ConvolutionFilter(3, 3, [0, 1, 0,  1, 1, 1,  0, 1, 0], 5);
      _cooling = new BitmapData(865, 465, false, 0xffffff);
      _offset = [new Point(), new Point()];
      addChild(new Bitmap(_fire));
      _createCooling(0.16);
      _createPalette(_currentFireColor = 0);
      addEventListener(Event.ENTER_FRAME, _update);
      //            stage.addEventListener(MouseEvent.CLICK, _onClick);
      private function _onClick(e:MouseEvent):void {
      if (++_currentFireColor == int(_fireColor.height / 32)) {
      _currentFireColor = 0;
      _createPalette(_currentFireColor);
      private function _createEmitter()isplayObject {
      var tf:TextField = new TextField();
      tf.selectable = false;
      tf.autoSize = TextFieldAutoSize.LEFT;
      tf.defaultTextFormat = new TextFormat('Verdana', 80, 0xffffff, true);
      tf.text = '__________________________________________';
      tf.x = (465 - tf.width) / 2;
      tf.y = 0;
      //            tf.y = (465 - tf.height) / 2;
      return tf;
      private function _createCooling(a:Number):void {
      _color = new ColorMatrixFilter([
      a, 0, 0, 0, 0,
      0, a, 0, 0, 0,
      0, 0, a, 0, 0,
      0, 0, 0, 1, 0
      _redArray = [];
      _greenArray = [];
      _blueArray = [];
      _alphaArray = [];
      if (gp < 1050112)
      _greenArray.push(255);
      _blueArray.push(255);
      } else {
      _redArray.push(gp);
      _blueArray.push(0);
      private function _update(e:Event):void {
      _grey.draw(_canvas);
      _grey.applyFilter(_grey, _grey.rect, ZERO_POINT, _spread);
      _cooling.perlinNoise(50, 50, 2, 982374, false, false, 0, true, _offset);
      _offset[0].x += 2.0;
      _offset[1].y += 2.0;
      _cooling.applyFilter(_cooling, _cooling.rect, ZERO_POINT, _color);
      _grey.draw(_cooling, null, null, BlendMode.SUBTRACT);
      _grey.scroll(0, -3);
        Legend
        • Correct Answers - 10 points
