1 Reply Latest reply on Sep 2, 2010 7:18 PM by JeffryHouser
    issue with flex lifecycle
    ShubaV
      I am trying to address an issue with flex lifecycle
      There is a ui component ( say CompA) comprising of multiple tabs with individual components used in each of them.
      CompA uses a data object that is used to populate the fields.
      On click of a button in another panel, I am setting the current state of the application to this view component and after CompA is completely rendered I would like to load the data object and populate the fields.
      The issue here is I cannot use the creationComplete event of CompA to load this data object because at this time not all components are  completely created. (creationComplete of each of those components is not completed yet),.
      When exactly can I load this data object into the UI fields. I am not able to figure out where even callLater() can be used .
      applicationComplete
      Event doesn’t seem to be an option, in this case.
