1. Re: Blue screen crash during BluRay playback
Studio North Films Sep 2, 2010 1:34 PM (in response to Spoot51)A blu screen is usually a hardware issue. could be driver related.
Baz
2. Re: Blue screen crash during BluRay playback
Spoot51 Sep 2, 2010 4:23 PM (in response to Studio North Films)Checked to make sure both drivers and firmware are most reccent for the Pioneer
burner. did not work. I'm completely at a loss.
3. Re: Blue screen crash during BluRay playback
ECBowen Sep 3, 2010 8:11 AM (in response to Spoot51)Does the system BSOD even if you have not launched the Blue Ray player software? Does your Blue Rays spin to the starting point fine and show the disc label in Windows Explorer?
Eric
ADK
4. Re: Blue screen crash during BluRay playback
Spoot51 Sep 3, 2010 8:29 AM (in response to ECBowen)No, system has not ever crashed except for when described above.
Software (CyberLink PowerDVD 9) plays ok. Std def DVDs, both store bought movies and ones I have created play fine. In addition, commercial BluRay movie DVDs play ok.The only time it crashes is when I put a BluRay DVD in that I authored in Ppro/Encore. In fact, all 3 BluRay DVDs I have made cause the thing to crash at roughly the same time frame. Menu with music shows fine, but when I select a chapter and start playing it crashes every time after 40-50 seconds. Exact same homemade DVDs have played fine on other pcs and in BluRay players for months, so I don't think it's the DVD. Per suggestion above I made sure both Pioneer firmware and drivers are current.
Thanks for thinking about this...
5. Re: Blue screen crash during BluRay playback
ECBowen Sep 3, 2010 8:48 AM (in response to Spoot51)What are you setting your audio sample rate and bit rate to on your Blue Ray encoding? What is your audio interface? Can you run a WinDBG on your memory dump file?
Eric
ADK
6. Re: Blue screen crash during BluRay playback
Spoot51 Sep 3, 2010 9:13 AM (in response to ECBowen)I will have to go back to old pc and look up project settings, but I believe the encoded audio track (alsway in stereo, not surround) is PCM 48000. I haven't ever changed the default settings in a project. Source files are various .wav, .mp3, and from my Sony HDR FX7, which mic settings are I don't know. In past I have also used tracks that I recorded into SoundBooth from old stereo LPs. When archiving my old records I cranked up the setting to 48000Hz and 24bit.
But again, when burning the DVDs it's always default settings and these discs have played and continue to play fine on other machines.
What is the hint here? Are my settings or mixing of audio sources a possible issue?
7. Re: Blue screen crash during BluRay playback
ECBowen Sep 3, 2010 9:41 AM (in response to Spoot51)The hint here is the fact the issue is tied to your encoded Blue Rays only and only on this system. Also this same system plays retail Blue Rays without issue. The issue happens after a repeatable amount of time after playback is started. The Discs are read properly by the Blue ray optical drive since they spin to the starting point and the disc lable is read by windows explorer. This tells me that the issue is either tied to the encoding your performing which means settings or to the playing software itself. Based on this the audio is the first probable culprit and should be ruled out first. Also the Cyberlink software has been sketchy at times in previous versions so that has to be looked at as well. The video and audio settings in the software need to be checked. That is where I would start until I see a WinDBG readout that points to something else.
Eric
ADK
8. Re: Blue screen crash during BluRay playback
Spoot51 Sep 3, 2010 10:28 AM (in response to Spoot51)Thanks, Eric. I'll try to check this stuff over the weekend. I am not literate enough to know how to use WINDBG yet, so I'll work on the other points. Your thinking process is very clear and I'm sure the answer will show up soon.
9. Re: Blue screen crash during BluRay playback
Bill Hunt Sep 3, 2010 3:17 PM (in response to Spoot51)After a BSOD, this ARTICLE might provide tips as to what is happening on this system, with these discs. Could be as simple as a bad driver.
As has been suggested, I would make sure that any/all drivers were updated, along with the firmware of the BD drive.
What brand of blank media are you using?
What is the Transcode bit-rate used?
10. Re: Blue screen crash during BluRay playback
Spoot51 Sep 3, 2010 5:20 PM (in response to Bill Hunt)Thanks, Bill. Good article. As stated above, Taiyo Juden blanks and default transcode settings. I 'm beginning to think it's CyberLink related. Will inform Forum when solved in case it may help someone in future....
11. Re: Blue screen crash during BluRay playback
Powered by Design Sep 4, 2010 2:48 PM (in response to Spoot51)It could be the disks you are using.
Have you tried another brand ?
As a test if the audio is the problem just delete it and burn a test disk and see if you still have the problems with no audio.
I like to stick with Verbatim disk. They have good quality.
GLenn
12. Re: Blue screen crash during BluRay playback
Spoot51 Sep 6, 2010 12:40 PM (in response to Spoot51)Thanks to everyone who answered. Eric, I'll buy you a beer next time you're on Phoenix! After uninstalling/reinstalling CyberLink9, I created a quick little project using HDV footage and lots of very high res slides (about 1 GB). Burned it into a re-writable TDK BluRay DVD (which was one of the discs causing the crash before) and it plays fine. I assume things will work from now on. Have not eliminated Taiyo Juden BluRay blanks as cause, but seriously doubt that was the culprit. It must have been something in the inital footage of the project, audio-vid-or effects/transitions or settings that caused the BSOD, since even on the Taiyo Juden problem final project disc the menu displayed and any chapter except chapter 1 worked fine.
thanks again...
13. Re: Blue screen crash during BluRay playback
ECBowen Sep 7, 2010 8:44 AM (in response to Spoot51)Excellent news and I always love a good beer. Cyberlink has been problematic over the last couple versions. I would not be suprised if that was the problem atleast vith the video driver or audio driver you were running.
Eric
ADK
