Hi
Currently i am working on a process in which i need to fetch the process id into the final form.ie.the process id should be displayed in the final output form.Can anyone tell dat how to do this?
Views
Total Likes
If you look at the process data exposed in a Set Value operation the variable id is the process ID.
Ideally, create and embed an XML Schema in your form. In my form, depicted below, I have three fields - firstName, lastName and processID.
You can then map the process ID into the form.
Steve
Views
Total Likes
