2 Replies Latest reply on Sep 7, 2010 1:14 AM by twessss
    focus navigation with enter key between controls
    twessss Level 1
      hi,
      i've an app and i wanna change control focuses one to other one with pressing enter key..i think keyFocusChange property solve my prob but i couldnt fix it..
      text input
      button
      helppp pls.
      thnx
        • 1. Re: focus navigation with enter key between controls
          krafttimd
          If the objects that do the navigation have a keyDown event you could listen for that event and switch the focus using the FocusManager. However, once an item has focus pressing the Tab key or Shift + Tab automatically seems to work fine for shifting focus within forms, ButtonBars, TabNavigators etc...
          If you need to do the navigation on pressing the enter button, the keyboardEvent raised by a keyDown event in on a flash.display.InteractivObject has a keyCode which you can inspect to determine if the enter key was pressed.
          T.K.
          • 2. Re: focus navigation with enter key between controls
            twessss Level 1
            thnx krafttimd for help..
            i solved it with an easily way..i used textInput s enter event and generate a handler.
            <s:TextInput id="kod" enter="kod_enterHandler(event)" />
            <s:TextInput id="sifre" enter="sifre_enterHandler(event)" />
            <mx:Button id="giris"  keyDown="giris_keyDownHandler(event)" click="checkLogin()"/>
            protected function kod_enterHandler(event:FlexEvent):void
            sifre.setFocus();
            protected function sifre_enterHandler(event:FlexEvent):void
            giris.setFocus();
            protected function giris_keyDownHandler(event:KeyboardEvent):void
            if(event.keyCode == Keyboard.ENTER) checkLogin();
