2 Replies Latest reply on Sep 3, 2010 9:44 AM by Arun Ganesh
    count of fields in ArrayCollection
    Devtron Level 3
      Hello,
      Let's say I have an ArrayCollection as so:
                [Bindable]
                private var ItemDGDataProvider:ArrayCollection = new ArrayCollection([
                    {name:"Item1",value:"21",qty:"3",cost:"12.21", apples: "1"},
                    {name:"Item2",value:"20",qty:"4",cost:"12.22", apples: "1"},
                    {name:"Item3",value:"22",qty:"5",cost:"12.23", apples: "1"},
                    {name:"Item4",value:"23",qty:"2",cost:"12.24", apples: "1"}
      How can I get the count of items? I do not need the total count, I need the field count, which in this case would be 5.
      What is the code to do that?
      I do not need the ArrayCollection.length, but instead, need ArrayCollection.FieldCount or something similar?
        • 1. Re: count of fields in ArrayCollection
          Arun Ganesh Level 3
          Hopefully this will help you.
          if(ItemDGDataProvider!=null && ItemDGDataProvider.length>0)
                              Alert.show(getPropertyCount(ItemDGDataProvider.getItemAt(0))+"");
          private function getPropertyCount(obj:Object):Number{
                          var count:int = 0;
                          for each (var prop:Object in obj)
                              count++;
                          return count;
          • 2. Re: count of fields in ArrayCollection
            Flex harUI Adobe Employee
            Probably something like ObjectUtil.getClassInfo().properties.length
