1 Reply Latest reply on Sep 5, 2010 10:11 PM by Anirudh Sasikumar
    Can not build export of application
    UncleJey7
      When i run my application in debug mode .. all works perfectly.
      But when i try build run-mode application. Flash builder returns warnings like that
      Описание Ресурс Путь Расположение Тип
      Design:itemPage is a module or application that is directly referenced. This will cause Design:itemPage and all of its dependencies to be linked in with fx. Using an interface is the recommended practice to avoid this. fx Неизвестно Проблема Flex
      map:mapEdit is a module or application that is directly referenced. This will cause map:mapEdit and all of its dependencies to be linked in with fx. Using an interface is the recommended practice to avoid this. fx Неизвестно Проблема Flex
      map:mapPage is a module or application that is directly referenced. This will cause map:mapPage and all of its dependencies to be linked in with fx. Using an interface is the recommended practice to avoid this. fx Неизвестно Проблема Flex
      menu:myMenu is a module or application that is directly referenced. This will cause menu:myMenu and all of its dependencies to be linked in with fx. Using an interface is the recommended practice to avoid this. fx Неизвестно Проблема Flex
      What does that meen? What i have to do?
      Google is don't know.
      PS Sorry for my english.
