7 Replies Latest reply on Sep 7, 2010 9:21 AM by RosieGp
    Datagrid result value
    RosieGp
      Hi all,
      I have a datagrid pulling data from SQL... Data looks like
      ID          Michigan_Produce      Item
      1           F                               Tea
      2           T                               Apples
      3           T                               Coffee
      Now i have a data grid to show this uising flex front end.
      The issue is where it says F or T i have to say False or True.
      Is there a way to do that in datagrid itself or i have to write some function...
      private
      function produceResult(event:ResultEvent):void
      if
      (event.result.length != 0)
      produceResults = event.result
      as ArrayCollection;
      returnData.dataProvider = produceResults;
      else
      Alert.show(
      "No records exists ");
      <mx:DataGrid
      id="returnData" width="814" height="282" fontWeight="bold">
      <mx:columns>
      <mx:DataGridColumn headerText="ID" dataField="ID" width="75"/>
      <mx:DataGridColumn headerText="Michigan Produced" dataField="Michigan_Produce" width="75"/>
      <mx:DataGridColumn headerText="Item" dataField="Item"/>
      </mx:columns>
      </mx:DataGrid>
      Final product should look like:
      1           False                            Tea
      2           True                             Apples
      3           True                             Coffee
      Any help is appreciated...
        • 1. Re: Datagrid result value
          ShardulSingh Level 3
          Pls try this. It will full fill your requirement.Let me know if u have any issue with this.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  //Let suppose this is from ur arraycollection which is showing the data from server side.
                  private var acFromServerSide : ArrayCollection = new ArrayCollection([
                  {ID: '1',Michigan_Produce : 'T',Item : 'Tea'},
                  {ID: '2',Michigan_Produce : 'F',Item : 'Tea'}
                  [Bindable]
                  private var acModified : ArrayCollection = new ArrayCollection();
                  private function onCC() : void
                      for each (var obj: Object in acFromServerSide )
                          if(obj.Michigan_Produce == "T")
                              obj.Michigan_Produce = "True";
                          else if(obj.Michigan_Produce == "F")
                              obj.Michigan_Produce = "False";
                          acModified.addItem(obj);
          </mx:Script>
              <mx:DataGrid id="dg" dataProvider="{acModified}" creationComplete="onCC()">
                     <mx:columns>
                             <mx:DataGridColumn dataField="ID" width="150"/>
                             <mx:DataGridColumn dataField="Michigan_Produce" width="150"/>
                             <mx:DataGridColumn dataField="Item" width="150"/>
                     </mx:columns>
              </mx:DataGrid>
          </mx:Application>
          with Regards,
          Shardul Singh Bartwal
          • 2. Re: Datagrid result value
            RosieGp Level 1
            I really appreciate your reply. I did the follwoing but still don't see the populated nothing shows up under Michigan Produce. Am i doing something wrong...
            I need that produceResult function as I'm pulling more data for text input columns. Please help...
            <mx:Script>
                <![CDATA[
                    private
            var returnData:ArrayCollection;
                 [Bindable] private var acModified : ArrayCollection = new ArrayCollection();
                  private function produceResult(event:ResultEvent):void {
                           if(event.result.length != 0)
                            {     dg.dataProvider = returnData;}
                           else {Alert.show("No records exists ");}
                        for each (var obj: Object in returnData )
            </mx:Script>
                       <mx:columns>
                       </mx:columns>
                </mx:DataGrid>
            </mx:Application>
            • 3. Re: Datagrid result value
              Subeesh Arakkan Level 4
              without modifying the dataprovider you can try something like this using itemrenderer
                   <mx:itemRenderer>
                        <fx:Component>
                             <mx:Label label="{data.Michigan_Produce == 'T' ? 'True' : 'False'}" />
                        </fx:Component>
                   </mx:itemRenderer>
              </mx:DataGridColumn>
              • 4. Re: Datagrid result value
                RosieGp Level 1
                @Subeesh,
                I have FB 3 on my machine so when I ran your code it give the folloing error:
                The prefix "fx" for element "fx:Component" is not bound.
                Sorry, im very new to flex, so it takes sometime for me to understand things...
                and in the following code:
                where did "data." come form, it is dataprovider right???
                • 5. Re: Datagrid result value
                  RosieGp Level 1
                  @Subeesh,
                  I got rid of the error.
                  The code that I'm using now is as following:
                  <mx:DataGridColumn
                  headerText="Michigan Produce" dataField="Michigan_Produce" width="150">
                    <mx:itemRenderer>
                      <mx:Component>
                        <mx:Label text="{data.Michigan_Produce == 'T' ? 'True' : 'False'}" />
                      </mx:Component>
                    </mx:itemRenderer>
                  But this always shows False, even if the value is 'T'. Why is this???
                  Thanks...
                  • 6. Re: Datagrid result value
                    data is coming from the dataProvider. Try this for the renderer
                    <mx:itemRenderer>
                         <mx:Component>
                              <mx:Label>
                                   <mx:Script>
                                        <![CDATA[
                                             override public function set data(value:Object):void
                                                  super.data = value;
                                                  text = data.Michigan_Produce == 'T' ? 'True' : 'False';
                                   </mx:Script>
                              </mx:Label>
                         </mx:Component>
                    </mx:itemRenderer>
                    • 7. Re: Datagrid result value
                      RosieGp Level 1
                      Subeesh,
                      Thanks for replying.
                      when i used the follwoing code: The whole application blew off. I did not see anything running... this is driving me crazy...
                      <mx:DataGridColumn
                      headerText="Michigan Produce" dataField="Michigan_Produce" width="75">
                      <mx:itemRenderer>
                           <mx:Component>
                                <mx:Label>
                                     <mx:Script>
                                          <![CDATA[
                                                    super.data = value;
                                     </mx:Script>
                                </mx:Label>
                           </mx:Component>
                      </mx:itemRenderer>
                      </mx:DataGridColumn >
                      ANy help is appreciated... Thanks in advance.
