8 Replies Latest reply on Sep 4, 2010 2:14 PM by Yuliaart
    Duplicate graphic in InDesign CS5 js
    Yuliaart Level 1
      I need to duplicate embedded graphic and it's not working:
      var myRoundCornerTopRightGroup = myCornerLogo.duplicate ([1, 1]);
      What am I missing.
      Thank you for your help.
      Yulia
        • 1. Re: Duplicate graphic in InDesign CS5 js
          Shonkyin Level 3
          I am sure that you have store image link to myCornerLogo.
          Try with below code
          var myRoundCornerTopRightGroup = myCornerLogo.parent.duplicate ([1, 1]);
          Shonky
          • 2. Re: Duplicate graphic in InDesign CS5 js
            Yuliaart Level 1
            No, it didn't work for me, and I was trying earlier with the frame of the logo itself and it was giving me error too.
            Yulia
            • 3. Re: Duplicate graphic in InDesign CS5 js
              Shonkyin Level 3
              If you send more code of your script then its easy to catch the error.
              Shonky
              • 4. Re: Duplicate graphic in InDesign CS5 js
                Yuliaart Level 1
                It's the code that used to work in CS4, but now I am trying to go a little bit a different route to make it work in CS5:
                var myCornerFrame = myDoc.pages[0].rectangles.add (myDoc.layers.item ("Die"));
                myCornerFrame.geometricBounds = ["-.0139 in",  "-.0139 in", "0.4236 in", "0.4236 in"];
                myCornerFrame.strokeWeight = 0;
                myCornerFrame.fillColor  = "None";
                var myDocPath = myDoc.filePath;
                var mySplit = myDoc.name.indexOf ("_");
                var myFileName = myDoc.name.slice (0,mySplit);
                var myFileNameNew = myFileName.slice (0,2);
                var myRootPath = myDocPath.parent.fsName;
                var myRootPath = myRootPath + "/";
                var mySplitPath = myRootPath.indexOf (myFileNameNew);
                var myPath = myRootPath.slice (0,mySplitPath);
                var myFolderPath = myPath + "/~prepress/colorSettings/";
                myCornerLogo = File (myFolderPath + "/topLeftRoundCorner.eps");
                try{
                if (myCornerLogo.exists){
                  myLinkArray = myCornerFrame.place (myCornerLogo);
                  myLinkArray[0].itemLink.unlink();
                catch (e){}
                if(myTopRightCheckbox == true){
                            myRoundCornerLeftBottomGroup=myCornerLogo;
                            myRoundCornerTopRightGroup.flipItem(Flip.HORIZONTAL, AnchorPoint.TOP_RIGHT_ANCHOR);
                            myRoundCornerTopRightGroup.move ([myPageWidth+.0625-.0486, myPageHeight/2-.0625]);
                            var myRoundCornerTopRightGroupPage1 = myRoundCornerTopRightGroup.duplicate ();
                            myRoundCornerTopRightGroupPage1.move (myDoc.pages[1]);
                            myRoundCornerTopRightGroupPage1.flipItem (Flip.HORIZONTAL, AnchorPoint.BOTTOM_LEFT_ANCHOR);
                            myRoundCornerTopRightGroupPage1.move (["-0.0139 in", myPageHeight/2-.0625]);
                It all works to the point of the pink line. I do get my logo placed and embedded.
                Thank you so much.
                Yulia
                • 5. Re: Duplicate graphic in InDesign CS5 js
                  Yuliaart Level 1
                  Pink line is no longer pick, so it's this line that it stops at:
                  Thank you.
                  • 6. Re: Duplicate graphic in InDesign CS5 js
                    Shonkyin Level 3
                    Above line showing that you have a File in myCornerLogo and your first post you trying to duplicate myCornerLogo. myCornerLogo not a document object. So instead of duplicating myCornerLogo you try to duplicate  myLinkArray[0].
                    Shonky
                    • 7. Re: Duplicate graphic in InDesign CS5 js
                      Shonkyin Level 3
                      try to replace with this
                      var myRoundCornerTopRightGroup = myLinkArray[0].duplicate ([1, 1]);
                      Shonky
                      • 8. Re: Duplicate graphic in InDesign CS5 js
                        Yuliaart Level 1
                        Got it, thank you very much.
                        Yulia
