6 Replies Latest reply on Sep 11, 2010 6:29 PM by RemyBlair
    php newbie
    RemyBlair
      Hi Guys, having seen the writing on the wall, I'm moving all my asp development to php, but I'm a bit stumped on dreamweavers behavior with php
      Whenever I do a php include and place my cursor between the " " and then select the file, dreameaver places the file name outside the quotation marks
      Other occaisions I delete a server behaviour from the panel, the code remains and is not deleted!
      Any ideas
      cheers
      Rem
        • 1. Re: php newbie
          MurraySummers Level 8
          How are you doing the includes?  What steps are you performing to get to the point where you have empty quotes?  When I use the INSERT | Server -Side Include or the include icon from the Insert toolbar, I am always challenged to browse to the file before the code is inserted.
          I cannot reproduce this symptom.
          • 2. Re: php newbie
            RemyBlair Level 1
            Hi Murray,
            Thanks for the reply.
            I select the include from the php menu
            the code is inserted as  <?php include(); ?>
            I then place " " as   <?php include(""); ?> my cursor is now between the quotation marks
            The screen then requests a refresh after which the filename box appears, I then navigate to the file, select it and  dreamweaver places the code like this outside of the brackets
                  modules/mod_CustomerSupport.html
            This happens every time without fail, the code is always inserted a line above the include
            Best regards
            Rem
            • 3. Re: php newbie
              Rob Hecker2-uhQIgt Level 2
              Dreamweaver is not a PHP IDE, although it is PHP friendly.
              Zend Studio is one of several PHP IDEs available.
              • 4. Re: php newbie
                25 Rabbits
                Dreamweaver sometimes likes to re-write code if it sees problems with basic html , you can modify this in  edit->preferences->code rewriting, if .php isnt there add it.
                you could also just type it in.. <?php include "path/to/file.php"; ?>
                • 5. Re: php newbie
                  Try it the way I suggested.
                  Place the cursor and use INSERT | Server-Side Include.  That way you never pass through the empty quotes state.
                  • 6. Re: php newbie
                    RemyBlair Level 1
                    Thanks Murray,
                    I'll do it your way, as you say it works.
                    Thanks for the help
                    Cheers
                    Remy
