6 Replies Latest reply on Jul 26, 2007 8:55 AM by Newsgroup_User
    Problems using rpc between Flex and CF
    this.sonix
      Hi
      I've got a problem sending objects between Flex and Coldfusion using the AMF Gateway of the newest Coldfusion Version.
      The transfer from CFC to Flex does work, but I can't send a complex object to a CFC.
      The error Message is:
      faultCode:Client.Message.Encoding faultString:'Cannot create class of type 'flex.HotlineSystem.bin.cf.Category'.' faultDetail:'Type 'flex.HotlineSystem.bin.cf.Category' not found.'
      Im totally going nuts ... the transfer from CF to Flex is working fine, the mapping between category.cfc and category.as ist working. But If I try to send an category Object from Flex to my CFC it is not.
      Hope someone can help.
      Merci!
      CFC Function:
      <cffunction name="insertCategory" access="public" returntype="void" output="false">
      <cfargument name="category" type="flex.HotlineSystem.bin.cf.Category" required="true">
      <cfquery name="insertCategory" datasource="hotline_system">
      INSERT INTO category (category_idCategory, name)
      VALUES ( #category.getCategory_IdCategory()#, '#trim(category.getName())#')
      </cfquery>
      category.cfc:
      <cfcomponent displayname="Category" alias="flex.HotlineSystem.bin.cf.Category" hint="I model a single Category">
      <cfproperty name="idCategory" type="numeric" default="0">
      <cfproperty name="category_idCategory" type="numeric" default="0">
      <cfproperty name="name" type="string" default="">
      <cfscript>
      //Initialize the CFC with the default properties values.
      variables.idCategory = 0;
      variables.category_idCategory = 0;
      variables.name = "";
      </cfscript>
      <cffunction name="init" output="false" returntype="flex.HotlineSystem.bin.cf.Category">
      <cfreturn this>
      </cffunction>
      <cffunction name="getIdCategory" output="false" access="public" returntype="any">
      <cfreturn variables.IdCategory>
      </cffunction>
      <cffunction name="setIdCategory" output="false" access="public" returntype="void">
      <cfargument name="val" required="true">
      <cfif (IsNumeric(arguments.val)) OR (arguments.val EQ "")>
      <cfset variables.IdCategory = arguments.val>
      <cfelse>
      <cfthrow message="'#arguments.val#' is not a valid numeric"/>
      </cfif>
      </cffunction>
      <cffunction name="getCategory_idCategory" output="false" access="public" returntype="any">
      <cfreturn variables.Category_idCategory>
      </cffunction>
      <cffunction name="setCategory_idCategory" output="false" access="public" returntype="void">
      <cfset variables.Category_idCategory = arguments.val>
      <cfelse>
      </cfif>
      </cffunction>
      <cffunction name="getName" output="false" access="public" returntype="any">
      <cfreturn variables.Name>
      </cffunction>
      <cffunction name="setName" output="false" access="public" returntype="void">
      <cfset variables.Name = arguments.val>
      </cffunction>
      </cfcomponent>
      category.as:
      package classes
      [Bindable]
      [RemoteClass(alias="flex.HotlineSystem.bin.cf.Category")]
      public dynamic class category
      public var idCategory:int;
      public var category_idCategory:int;
      public var name:String;
      public function category(){
      public function fill(idCategory:int, category_idCategory:int, name:String):void{
      this.idCategory = idCategory;
      this.category_idCategory = category_idCategory;
      this.name = name;
      public function getIdCategory():int{
      return this.idCategory;
      public function setIdCategory():void{
      public function getCategory_IdCategory():int{
      return this.category_idCategory;
      public function setCategory_IdCategory(category_idCategory:int):void{
      public function setName(name:String):void{
      this.name = name;
      public function getName():String{
      return this.name;
        • 1. Re: Problems using rpc between Flex and CF
          Level 7
          The top level flex.* package is reserved for Flex only, you cannot use this
          with ColdFusion CFCs.
          • 2. Re: Problems using rpc between Flex and CF
            Level 7
            That is, try a different package name for your CFCs to something other than
            flex.*
            Pete
            • 3. Re: Problems using rpc between Flex and CF
              this.sonix Level 1
              Hi
              first of all: thanks for replying.
              I changed the package to "da.HotlineSystem.bin.cf.Category" and my webdirectory to "..\CFusionMX7\wwwroot\da\HotlineSystem\bin\cf", but there is still the same error message:
              faultCode:Client.Message.Encoding faultString:'Cannot create class of type 'da.HotlineSystem.bin.cf.Category'.' faultDetail:'Type 'da.HotlineSystem.bin.cf.Category' not found.'
              I changed the CFC argument types to any but it makes no difference.
              I think it has something to do with the mapping between the category.as and the category.cfc
              Did I forget anything in my cfc or as files?
              Heres my service.config.xml from CFusionMX7\wwwroot\WEB-INF\flex
              <?xml version="1.0" encoding="UTF-8"?>
              <services-config>
              <services>
              <service id="coldfusion-flashremoting-service"
              class="flex.messaging.services.RemotingService"
              messageTypes="flex.messaging.messages.RemotingMessage">
              <adapters>
              <adapter-definition id="cf-object" class="coldfusion.flash.messaging.ColdFusionAdapter" default="true"/>
              </adapters>
              <destination id="ColdFusion">
              <channels>
              <channel ref="my-cfamf"/>
              </channels>
              <properties>
              <source>*</source>
              <!-- define the resolution rules and access level of the cfc being invoked -->
              <access>
              <!-- Use the ColdFusion mappings to find CFCs, by default only CFC files under your webroot can be found. -->
              <use-mappings>true</use-mappings>
              <!-- allow "public and remote" or just "remote" methods to be invoked -->
              <method-access-level>remote</method-access-level>
              </access>
              <property-case>
              <!-- cfc property names -->
              <force-cfc-lowercase>false</force-cfc-lowercase>
              <!-- Query column names -->
              <force-query-lowercase>false</force-query-lowercase>
              <!-- struct keys -->
              <force-struct-lowercase>false</force-struct-lowercase>
              </property-case>
              </properties>
              </destination>
              </service>
              </services>
              <channels>
              <channel-definition id="my-cfamf" class="mx.messaging.channels.AMFChannel">
              <endpoint uri=" http://{server.name}:{server.port}{context.root}/flex2gateway/" class="flex.messaging.endpoints.AMFEndpoint"/>
              <properties>
              <polling-enabled>true</polling-enabled>
              <serialization>
              <instantiate-types>true</instantiate-types>
              </serialization>
              </properties>
              </channel-definition>
              </channels>
              <logging>
              <target class="flex.messaging.log.ConsoleTarget" level="Error">
              <properties>
              <prefix>[Flex] </prefix>
              <includeDate>false</includeDate>
              <includeTime>false</includeTime>
              <includeLevel>false</includeLevel>
              <includeCategory>false</includeCategory>
              </properties>
              <filters>
              <pattern>Endpoint.*</pattern>
              <pattern>Service.*</pattern>
              <pattern>Configuration</pattern>
              <pattern>Message.*</pattern>
              </filters>
              </target>
              </logging>
              <system>
              </system>
              </services-config>
              • 4. Re: Problems using rpc between Flex and CF
                this.sonix Level 1
                Nobody?
                hm, .. is it possible to send complex objects from flex to coldfusion, or is it only possible to consume?
                • 5. Re: Problems using rpc between Flex and CF
                  this.sonix Level 1
                  Problem solved:
                  It is apparently not possible to transfer an object of an action script class to coldfusion.
                  The solution is to encapsulate the object (in my example category) in an array.
                  Strange, ... but it works.
                  best regards
                  • 6. Re: Problems using rpc between Flex and CF
                    Level 7
                    Ah right, the issue is that ColdFusion supports two styles of providing arguments
                    to CFC functions - ordered arguments and named arguments.
                    If you call your RemoteObject method with a single complex object it thinks
                    you are providing a Struct of named arguments. This is a legacy feature from
                    the original Flash Remoting functionality and CFCs. There are several work
                    arounds... wrapping it in an Array is one such workaround, another is to
                    simply provide a second argument so that it will think the complex object
                    is just the first ordered argument rather than a struct of named arguments.
