7 Replies Latest reply on Nov 12, 2010 7:29 AM by Colin Brougham
    MPE GPU Acceleration with a GTX 480
    smitpr1
      I added the line "GeForce GTX 480" in the cuda_supported_cards.txt file.  MPE became available upon doing so.  However rendering is faster in software than using the GPU.  Did I miss something?
        • 1. Re: MPE GPU Acceleration with a GTX 480
          Harm Millaard Level 7
          That may be because software render does not use maximum render quality by default and hardware assisted render uses maximum quality all the time. In your case not using maximum quality software render ostensibly outweighs the hardware render. Look here on the background page for more information: PPBM5 Benchmark
          • 2. Re: MPE GPU Acceleration with a GTX 480
            Alan Craven Level 4
            Did you check that the settings in the Nvidia control panel 3D Settings, and your Premiere project are correct for using the hardware acceleration?  I had to reset both of these after editing the CUDA txt file.
            • 3. Re: MPE GPU Acceleration with a GTX 480
              smitpr1 Level 1
              When I try to run the PPBM CS5 Benchmark I get an error saying:
              "This project was last used with Mercury Playback Engine GPU Acceleration, which is not available on this system.  Mercury Playback Engine Software Only will be used."
              Not sure what to look at from here.
              • 4. Re: MPE GPU Acceleration with a GTX 480
                smitpr1 Level 1
                In the Nvidia Control panel it mentions Adobe CS4 (not sure why - I never owned that version - using CS5).  Under manage 3D settings the CUDA - GPUs is set to GeForce GTX 480.  Is this all I need to check for?
                • 5. Re: MPE GPU Acceleration with a GTX 480
                  smitpr1 Level 1
                  Disregard my note.  Some how I mistyped to say 470 instead of 480 in the text file.  It was right and I was rechecking and somehow changed it.
                  • 6. Re: MPE GPU Acceleration with a GTX 480
                    GWeglarz
                    I installed the GTX 480, added it to the text file,. Now I have
                    MPE GPPU available as well as MPE software available. My tests show no difference. The GPU is only used about 7% and my CPU's are still maxed out.
                    Dell XPS 710
                    Property Value
                    Summary
                    Number of Logical Processors 4
                    Number of Physical Processors 1
                    CPU #1 Intel Core 2 Extreme QX6700
                    CPU Name Intel(R) Core(TM)2 Quad CPU @ 2.66GHz
                    CPU Code Name Kentsfield
                    Vendor GenuineIntel
                    Number of Bits 64
                    Instruction Set MMX, SSE, SSE2, SSE3, SSSE3, ET64, XD, VMX, EST
                    Platform Name Socket 775 LGA
                    Revision B3
                    Technology 65 nm
                    Original Clock 2666 MHz
                    Original System Clock 266 MHz
                    Original Multiplier 10.1
                    CPU Clock 2660 MHz
                    System Clock 265.4 MHz
                    FSB 1061.4 MHz
                    Number of Cores 4
                    Core #1
                    Speed 1592.2 MHz
                    Multiplier 6.0
                    Core #2
                    Speed 1592.2 MHz
                    Multiplier 6.0
                    Core #3
                    Speed 1592.2 MHz
                    Multiplier 6.0
                    Core #4
                    Speed 1592.2 MHz
                    Multiplier 6.0
                    Virtual Technology Supported Yes
                    Hyper Threading Supported No
                    Cache
                    L1 Data Cache 4 x 32 KBytes
                    L1 Instructions Cache 4 x 32 KBytes
                    L2 Cache 2 x 4096 KBytes
                    Geoffrey
                    • 7. Re: MPE GPU Acceleration with a GTX 480
                      Colin Brougham Level 6
                      Did you set your project to use hardware MPE, or is it still in software mode?
