2 Replies Latest reply on Sep 4, 2010 10:05 AM by shawn234
    array loop to change variables?
      The plan is to set up variables to react to a flashvars value like this:
      [code=html]<param name="flashvars" value="mainVars=1" />[/code]
      var videoArray:Array;
      var videoTitle:String;
      var videoFile:String;
      function onEnterFrame(){
          for(var i=videoArray.length-1;i>0;i++){
                      videoTitle="Show the video's change";
                  else if(i==1){
                      videoTitle="This is the second one";
      There would be many mainVars (over 100, actually) and this setup isn't working.  Could someone please help fix this problem?
      Message was edited by: shawn234
        • 1. Re: array loop to change variables?
          there are so many problems it's hard to tell what you want to do.
          but to start:
          1.  you almost certainly don't want to use an enterframe loop there
          2.  the parameter i should be decrementing, not incrementing
          3.  _root.mainVar is not the same as mainVars
          4.  you almost certainly don't want to use a while-loop there
          • 2. Re: array loop to change variables?
            shawn234 Level 1
            Oops, the mainVars was a typo.
            What I want to have as the finished product is a video page of multiple video players, each player with a different mainVar value.  The mainVar would tell the videoArray what to change the simplified videoTitle and videoFile variables to.
            That's the plan.  I don't know how to impliment it.  I figured an array would be a good choice since the array can have infinite "i" values, but I could be horribly wrong...
