1 Reply Latest reply on Sep 5, 2010 7:26 AM by Mylenium
    How to customize shortcut keys?
    ingvarai Level 1
      I tried this:
      http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&extid=1698043#
      but I must be doing smt wrong, because all I get is "You must have CS4 or later" and I have both CS4 and CS5. I put the script(s) in the scripts folder under After Effects. Actually, is is assumed famliliarity with running scripts, and I am new to his in Adobe products.
      The reason I must alter the shortcuts is that I live in Norway, and the keyboard layout here is very different from thew US keyboard whan it comes to many, if not most of the special characters. Which means that many of the default shortcuts don't work.
      Ingvar
        • 1. Re: How to customize shortcut keys?
          try to set your system language and region temporarily to US English. There is an issue with running these scripts in non-english environments, which of course somewhat defeats the purpose. If that doesn't work, I'm afraid you will have to modify the After Effects Shortcuts.txt files manaully. Location is the same as the normal prefs as explained here.
          Mylenium
