5 Replies Latest reply on Aug 29, 2007 12:14 PM by Captiv8r
      My project is being saved as a swf and imported into another program for publishing as an exe. However the skin functionality does not work?
        • 1. Re: skins
          CatBandit Level 3
          Information please...
          • 2. Re: skins
            DeveloperKJ Level 1
            What do you need to know?
            • 3. Re: skins
              CatBandit Level 3
              Nothing - sorry to have troubled you with the question. Captivate skins that include borders need access to the _skins file generated during publishing. Because you are embedding the Captivate SWF inside another application, that file is probably not being seen when needed, or perhaps your link is to the wrong Captivate output file. Try publishing without borders for the skin, or use one of the BMP playbar styles. Might help ...
              • 4. Re: skins
                Can someone assist? I am also trying to publish a SWF captivate in a webpage and the skin does not appear? How do you import both swf and swf.skin files in a webpage?
                • 5. Re: skins
                  Hi GRN MM and welcome to our community
                  What you do is to point at the skin.SWF and make sure that both it and the main movie.SWF are in the same folder. Internally, the skin.SWF knows to look for the main movie .SWF.
                  Hopefully that helps... Rick
