3 Replies Latest reply on Sep 9, 2010 10:42 PM by kglad
    No result with this code
    0slimjimmy0
      The problem is that it won't add 100 to the score.
      File: http://www.mediafire.com/?3o7qo4w1ou4j5cd
      Code for frame 1(Menu):
      stop();
      Score = 0;
      Code for frame 2(Level):
      stop();
      Score = Score;
      Points.text = "Score: " + Score;//"Points" is the instance name of the Score text box which is Dynamic Text. "Score" is the variable for the text box.
      Code for coins:
      onClipEvent (enterFrame) {
      if (this.hitTest(_root.player))
        unloadMovie(this);
        score += 100
      Code for player:
      onClipEvent (load) {
      speed = 5;
      gravity = 0;
      jumpSpeed = 5;
      jumping = false;
      gravityAcc = 0.3;
      if (Key.isDown(Key.RIGHT))
        this._x += speed;
        this.gotoAndStop(1);
      if (Key.isDown(Key.LEFT))
        this._x -= speed;
        this.gotoAndStop(2);
      if (Key.isDown(Key.UP))
        jumping = true;
      if (jumping)
        this._y -= jumpSpeed;
      gravity += gravityAcc;
      this._y += gravity;
      if (this.hitTest(_root.ground))
        this._y -= gravity;
        gravity = 0;
        jumping = false;
      if (this.hitTest(_root.coin))
        Score += 100;
        • 1. Re: No result with this code
          try:
          stop();
          Score = 0;
          stop();
          Score = Score;
          Code for coins:
            unloadMovie(this);
            _parent.Score += 100
          Code for player:
          speed = 5;
          gravity = 0;
          jumpSpeed = 5;
          jumping = false;
          gravityAcc = 0.3;
            this._x += speed;
            this._x -= speed;
            jumping = true;
          if (jumping)
          this._y += gravity;
            this._y -= gravity;
            gravity = 0;
            jumping = false;
            _parent.Score += 100;
          • 2. Re: No result with this code
            0slimjimmy0 Level 1
            Thanks for your help
            • 3. Re: No result with this code
              you're welcome.
