15 Replies Latest reply on Sep 7, 2010 11:09 PM by Subeesh Arakkan
    Data changing while scrolling in grid
    pickler1186
      hi...i'm adding textInput inside a data grid dynamically...the last column of the datagrid i'm adding a HBox inside wich i dynamically add textInput boxes on creationComplete event of the HBox...but when i enter a value in one of the textBoxes and scroll the grid and come back...the value appears inside anothr textBox and it continues to change when i keep scrolling....any solution on this??
        • 1. Re: Data changing while scrolling in grid
          Subeesh Arakkan Level 4
          it is due to the renderer recycling . Check this page for more info.
          http://www.adobe.com/devnet/flex/articles/itemrenderers_pt1.html
          • 2. Re: Data changing while scrolling in grid
            pickler1186 Level 1
            can you suggest me a solution for this problem?
            • 3. Re: Data changing while scrolling in grid
              yes, post your renderer code here
              • 4. Re: Data changing while scrolling in grid
                pickler1186 Level 1
                <mx:AdvancedDataGrid
                rowCount="10" width="96%" id="dgMetrics" wordWrap="true" variableRowHeight="true" sortExpertMode="true" sortItemRenderer="util.ui.AdvDatagridItemRenderer">
                <mx:columns>
                <mx:AdvancedDataGridColumn headerText="Category" wordWrap="true" headerWordWrap="true"/>
                <mx:AdvancedDataGridColumn headerText="Metrics Name" dataField="2" wordWrap="true" headerWordWrap="true"/>
                <!--<mx:AdvancedDataGridColumn headerText="Description" dataField="3" wordWrap="true" headerWordWrap="true"/> -->
                <mx:AdvancedDataGridColumn headerText="Current Value" id="currValue" headerWordWrap="true"/>
                <mx:AdvancedDataGridColumn headerText="Unit" dataField="7" wordWrap="true" headerWordWrap="true"/>
                <mx:AdvancedDataGridColumn headerText="Set Value" id="value" headerWordWrap="true" />
                <mx:AdvancedDataGridColumn headerText="Month" visible="false" headerWordWrap="true"/>
                </mx:columns>
                <mx:rendererProviders>
                <mx:AdvancedDataGridRendererProvider column="{value}" depth="2">
                <mx:renderer>
                <mx:Component>
                <mx:HBox width="100%" verticalAlign="middle" horizontalAlign="center" dataChange="{generateElement(data[5],data[6])}">
                <mx:Script>
                <![CDATA[
                import
                mx.binding.utils.BindingUtils;
                import mx.containers.HBox;
                import util.ui.ImageRenderer;
                import org.alivepdf.images.ImageFormat;
                import mx.graphics.ImageSnapshot;
                import mx.controls.Image;
                import mx.controls.ToolTip;
                import mx.controls.RadioButton;
                import mx.events.DateChooserEvent;
                import mx.events.StateChangeEvent;
                import mx.events.FlexEvent;
                import mx.events.CloseEvent;
                import vo.metricsmanagement.projectspecificmetrics.MetricsPeriodicValueVO;
                import mx.validators.NumberValidator;
                import mx.controls.Alert;
                import mx.controls.DateField;
                import mx.controls.TextInput;
                import mx.controls.Label;
                private function generateElement(isDate : int, endDate : Date) : void
                var tDate:Date = new Date();
                var enblFlag:Boolean;
                if(endDate>tDate)
                enblFlag =
                true;
                else
                enblFlag =
                false;
                this.removeAllChildren();
                if(this.getChildren().length ==0)
                if(isDate == 1)
                var date:DateField = new DateField();
                date.enabled = enblFlag;
                date.width = 120;
                date.toolTip =
                "Leave blank if there is no value for this periodicity";
                var clearDate : ImageRenderer = new ImageRenderer();
                clearDate.toolTip =
                "Click here to clear date and save as NA";
                clearDate.width = 12;
                clearDate.height = 12;
                if(enblFlag == true)
                var hbox:HBox = new HBox();
                hbox.width = 10;
                this.addChild(hbox);
                this.addChild(date);
                this.addChild(clearDate);
                clearDate.addEventListener(MouseEvent.CLICK,
                function():void{
                date.selectedDate =
                null;
                var arr:Array = outerDocument.dgMetrics.selectedItem as Array;
                outerDocument.iMetricId = arr[1];
                outerDocument.isDate = 0;
                outerDocument.strValue =
                "NA";
                outerDocument.updateValue();
                date.addEventListener(MouseEvent.CLICK,
                function():void{
                outerDocument.iMetId = arr[1];
                date.addEventListener(FocusEvent.FOCUS_OUT,
                function():void{
                //var arr:Array = outerDocument.dgMetrics.selectedItem as Array;
                for(var i:int = 0;i<outerDocument.acMetricValue.length;i++)
                var tempBean:MetricsPeriodicValueVO = new MetricsPeriodicValueVO();
                tempBean = outerDocument.acMetricValue.getItemAt(i)
                as MetricsPeriodicValueVO;
                if(outerDocument.iMetId == tempBean.metricsId)
                outerDocument.acMetricValue[i].value = date.selectedDate;
                outerDocument.existsFlag =
                true;
                break;
                outerDocument.iMetricId = outerDocument.iMetId;
                outerDocument.isDate = 1;
                outerDocument.valDate = date.selectedDate;
                else
                var txtInput:TextInput = new TextInput();
                txtInput.enabled = enblFlag;
                txtInput.width = 120;
                txtInput.toolTip =
                "Enter \"na or NA\" or leave blank if there is no value for this periodicity";
                this.addChild(txtInput);
                if(outerDocument.pageInit == true)
                //txtInput.text = outerDocument.acMetricValue[0].val;
                Alert.show(
                "1 :"+outerDocument.acMetricValue[i].value.toString());
                //Alert.show(outerDocument.dgMetrics.editedItemPosition.toString());
                txtInput.addEventListener(TextEvent.TEXT_INPUT,
                function(event:TextEvent):void{
                var regExpD:RegExp = new RegExp("\\d");
                var regExpNA:RegExp = new RegExp("NA|na");
                var regExpN:RegExp = new RegExp("N|n");
                var regExpA:RegExp = new RegExp("A|a");
                var regExpDot:RegExp = new RegExp("\\.");
                if(regExpNA.test(txtInput.text)){
                event.preventDefault();
                else{
                if(txtInput.text == ''){
                if(regExpD.test(event.text) || regExpN.test(event.text)){
                else{
                else if(txtInput.text == 'N' || txtInput.text == 'n'){
                if(!regExpA.test(event.text)){
                else{
                if(!regExpD.test(event.text)){
                if(regExpDot.test(event.text)){
                if(txtInput.text.indexOf("\.") > 0){
                else{
                //txtInput.addEventListener(,function():void{
                txtInput.addEventListener(FocusEvent.FOCUS_OUT,
                function():void{
                outerDocument.acMetricValue[i].value = txtInput.text.toUpperCase();
                //BindingUtils.bindProperty(txtInput,"text",outerDocument.acMetricValue[i].value,"String") ;
                //txtInput.text = outerDocument.acMetricValue[i].value.toString();
                true;
                break;
                //Alert.show(outerDocument.iMetId.toString());
                outerDocument.strValue = txtInput.text.toUpperCase();
                </mx:Script>
                <!--<mx:TextInput enabled="{outerDocument.enableSetValueLink(data[6])}" />
                <mx:DateField-->
                </mx:HBox>
                </mx:Component>
                </mx:renderer>
                </mx:AdvancedDataGridRendererProvider>
                <mx:AdvancedDataGridRendererProvider column="{currValue}" depth="2">
                <mx:renderer>
                <mx:Component>
                <mx:HBox width="100%" horizontalAlign="center">
                <mx:Label text="{outerDocument.displayCurrentValue(data[5],data[8])}"/>
                </mx:HBox>
                </mx:Component>
                </mx:renderer>
                </mx:rendererProviders>
                </mx:AdvancedDataGrid>
                • 5. Re: Data changing while scrolling in grid
                  pickler1186 Level 1
                  please note that it is now in the dataChange event of the HBox...but initially i put it in the CreationComplete event...
                  • 6. Re: Data changing while scrolling in grid
                    okay. can you post a simple test case.
                    • 7. Re: Data changing while scrolling in grid
                      pickler1186 Level 1
                      hi Subeesh,
                           here's a simple example.
                      <mx:Application
                      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
                      creationComplete="doInit();"
                      <mx:VBox width="100%" height="100%" horizontalAlign="center">
                      <mx:VBox width="95%" height="100%" horizontalAlign="center">
                      <mx:VBox width="100%" height="13%" borderStyle="solid" borderColor="#000000">
                      </mx:VBox>
                      <mx:HBox width="100%" height="2%">
                      </mx:HBox>
                      <mx:VBox width="100%" height="47%" borderStyle="solid" borderColor="#000000" horizontalAlign="center">
                      <mx:HBox width="100%" height="5%">
                      </mx:HBox>
                      <mx:AdvancedDataGrid rowCount="10" width="96%" id="dgMetrics" wordWrap="true" variableRowHeight="true" sortExpertMode="true" >
                      <mx:columns>
                      <mx:AdvancedDataGridColumn headerText="Name" dataField="name" wordWrap="true" headerWordWrap="true"/>
                      <mx:AdvancedDataGridColumn headerText="Creator" id="crtor" dataField="creator" headerWordWrap="true"/>
                      <mx:AdvancedDataGridColumn headerText="Publisher" dataField="publisher" wordWrap="true" headerWordWrap="true"/>
                      </mx:columns>
                      <mx:AdvancedDataGridRendererProvider column="{value}" >
                      <mx:renderer>
                      <mx:Component>
                      <mx:HBox width="100%" verticalAlign="middle" horizontalAlign="center" creationComplete="{generateElement()}">
                      <mx:Script>
                      <![CDATA[
                      import mx.binding.utils.BindingUtils;
                      private function generateElement() : void
                      </mx:Script>
                      </mx:HBox>
                      </mx:Component>
                      </mx:renderer>
                      <mx:HBox>
                      <mx:Button label="Save All" id="btnSaveAll" click="" />
                      </mx:HBox>
                      <mx:Spacer height="2%">
                      </mx:Spacer>
                      </mx:VBox>
                      </mx:VBox>
                      </mx:VBox>
                      <mx:Script>
                      <![CDATA[
                      import mx.events.ScrollEvent;
                      import mx.events.AdvancedDataGridEvent;
                      import mx.utils.StringUtil;
                      import mx.rpc.events.FaultEvent;
                      import mx.collections.ArrayCollection;
                      import mx.managers.PopUpManager;
                      Bindable]
                      public var myData : ArrayCollection = new ArrayCollection();
                      private function doInit() : void
                      myData =
                      myData.addItem({name:
                      "Name1", creator: "Test", publisher: "Sample"});
                      "Name2", creator: "Test", publisher: "Sample"});
                      "Name3", creator: "Test", publisher: "Sample"});
                      "Name4", creator: "Test", publisher: "Sample"});
                      "Name5", creator: "Test", publisher: "Sample"});
                      "Name6", creator: "Test", publisher: "Sample"});
                      "Name7", creator: "Test", publisher: "Sample"});
                      "Name8", creator: "Test", publisher: "Sample"});
                      "Name9", creator: "Test", publisher: "Sample"});
                      "Name10", creator: "Test", publisher: "Sample"});
                      "Name11", creator: "Test", publisher: "Sample"});
                      "Name12", creator: "Test", publisher: "Sample"});
                      dgMetrics.dataProvider = myData;
                      private function handleFault(event : FaultEvent) : void
                      var errorMsg: String = event.fault.rootCause.message.toString();
                      Alert.show(errorMsg,
                      "Error", Alert.OK, this);
                      </mx:Script>
                      </mx:Application>
                      • 8. Re: Data changing while scrolling in grid
                        Check the modified code. The idea is to persist the textInput text in the dataProvider itself so that its value can be reset whenever the renderer is recycled.
                        <mx:Application
                                       </mx:VBox>
                                       </mx:HBox>
                                            </mx:HBox>
                                                 <mx:columns>
                                                 </mx:columns>
                                                           <mx:renderer>
        <mx:Component>
        <mx:Script>
        <![CDATA[
        private var txtInput:TextInput;
        txtInput = new TextInput();
        txtInput.addEventListener(TextEvent.TEXT_INPUT, onTextInput);
        override public function set data(value:Object):void
        super.data = value;
        if(txtInput)
        if(data && data.text)
        txtInput.text = data.text;
        else
        txtInput.text = "";
        private function onTextInput(event:TextEvent):void
        data.text = txtInput.text;
        </mx:Script>
        </mx:HBox>
        </mx:Component>
                                                           </mx:renderer>
                                            <mx:HBox>
                                            </mx:HBox>
                                            </mx:Spacer>
                                       </mx:VBox>
                                  </mx:VBox>
                             </mx:VBox>
                             <mx:Script>
                                  <![CDATA[
                        Bindable]
                                            myData =
                             </mx:Script>
                        </mx:Application>
                        • 9. Re: Data changing while scrolling in grid
                          pickler1186 Level 1
                          hi subeesh,
                               I tried ur code...but still the values are disappearing for some text boxes...it doesnt reappear in any other textBox...but the value is disappearin when i scroll....any idea?
                          thanks,
                          abraham
                          • 10. Re: Data changing while scrolling in grid
                            try listening for the change event instead of textinput event.
                            change
                            to
                            txtInput.addEventListener(Event.CHANGE, onTextInput);
                            private function onTextInput(event:Event):void
                            • 11. Re: Data changing while scrolling in grid
                              pickler1186 Level 1
                              now the values are disappearing all together....not working yet
                              • 12. Re: Data changing while scrolling in grid
                                pickler1186 Level 1
                                for the text input change event...when i enter a 2 digit number say 23 and scroll down  and come back...the 2 stays ter but the 3 disappears
                                • 13. Re: Data changing while scrolling in grid
                                  well this code is working for me. which version is your sdk
                                  <mx:Application
                                                 </mx:VBox>
                                                 </mx:HBox>
                                                      </mx:HBox>
                                                           <mx:columns>
                                                           </mx:columns>
        <mx:renderer>
        <mx:Component>
        <mx:Script>
        <![CDATA[
        super.data = value;
        if(txtInput)
        else
        txtInput.text = "";
        </mx:Script>
        </mx:HBox>
        </mx:Component>
        </mx:renderer>
                                                      <mx:HBox>
                                                      </mx:HBox>
                                                      </mx:Spacer>
                                                 </mx:VBox>
                                            </mx:VBox>
                                       </mx:VBox>
                                       <mx:Script>
                                            <![CDATA[
                                  Bindable]
                                                      myData =
                                       </mx:Script>
                                  </mx:Application>
                                  • 14. Re: Data changing while scrolling in grid
                                    pickler1186 Level 1
                                    hey subeesh...thanks a lot...it worked...the problem for me was in tht event listener...when u fire textinput event listener...the textInput.text doesnt giv me the last entered text...so in the event listener function i did data.text = textInput.text+event.text......tht wrkd fr me...and now its fine...thanks a lot for ur help
                                    • 15. Re: Data changing while scrolling in grid
                                      pickler1186 Level 1
                                      yea ur code is also wrkin...whn i copy pasted it wrkd...thanks a lot again
