10 Replies Latest reply on Sep 13, 2010 6:28 PM by Yue_Hong
    LocalConnection in Flex 4
    Yue_Hong Level 1
      Is there any example or tutorial on LocalConnection in Flex 4? I have done online searching but can't find one example that works on Flex 4. Thanks.
        • 1. Re: LocalConnection in Flex 4
          Flex harUI Adobe Employee
          If it works in Flex 3, it should work the same in Flex 4.
          • 2. Re: LocalConnection in Flex 4
            Yue_Hong Level 1
            Thanks for your reply. I have tried but Flex shows error message.
            import mx.events.FlexEvent;
            private var conn:LocalConnection;
                           protected function initConn():void{
                                conn = new LocalConnection();
                           protected function sendMessage():void {
                                conn.send("taskConnection", "localconnectionHandler", "wahahhaahahaah");
            The error:
            1061: Call to a possibly undefined method send through a reference with static type LocalConnection.
            • 3. Re: LocalConnection in Flex 4
              Is that in an MXML script block?  If it is in AS file, then you may just
              need to
                  import flash.net.LocalConnection;
              • 4. Re: LocalConnection in Flex 4
                Yue_Hong Level 1
                I have just added in import flash.net.LocalConnection; into <fx:Script> tag. But the same error is still appear.
                • 5. Re: LocalConnection in Flex 4
                  It compiles just fine for me even without the import.  Try a new simple test
                  project and see what happens.
                  • 6. Re: LocalConnection in Flex 4
                    Yue_Hong Level 1
                    I have tried to copy and paste into new one, but it appears to be more errors.
                    <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                xmlns:mx="library://ns.adobe.com/flex/mx" applicationComplete="initConn()">
                         <fx:Script>
                              <![CDATA[
                         </fx:Script>
                         <fx:Declarations>
                              <!-- Place non-visual elements (e.g., services, value objects) here -->
                         </fx:Declarations>
                    </s:WindowedApplication>
                    The errors are:
                    1046:Type was not found or was not a compile-time constant:LocalConnection.
                    1180: Call to a possibly undefined method LocalConnection.
                    Why is the errors appear? How can I solve the problem? Thanks.
                    • 7. Re: LocalConnection in Flex 4
                      Dunno, try it in a non-AIR application.
                      • 8. Re: LocalConnection in Flex 4
                        Yue_Hong Level 1
                        yeah, I have just try on non-air application and it seems to be working fine.... So, how can I fix it to have it work on air application? Thanks.
                        • 9. Re: LocalConnection in Flex 4
                          An AIR app worked for me.  Is your AIR project just one file?  Maybe you
                          have another class or variable named LocalConnection?
                          • 10. Re: LocalConnection in Flex 4
                            Yue_Hong Level 1
                            Thanks a lot for your help. I just found that my experiment file name is LocalConnection. After changing the name, the problem solves.
