5 Replies Latest reply on Sep 6, 2010 4:17 AM by Techi Panda
    script to plug-in
    Techi Panda Level 2
      Hi scripters
      I am trying to learn plug-in creation here is my first step
      and this is my one line script file.
      alert(app.selection[0].geometricBounds);
      Now I want to make this action as plug-in
      from where  I have to start? I am using Win XP and ID CS3
      thanks in advance
      regards
      a r  u l
        • 1. Re: script to plug-in
          A good start would be to ask in the InDesign SDK forum!
          To get you up and running, use this checklist:
          I have
          [  ] InDesign CS3 debug version (not required but strongly recommended)
          [  ] SDK (= Software Development Kit) for InDesign CS3 (freely downloadable, but you'll have to search for it)
          [  ] Microsoft Visual Studio (check the SDK requirements; I'm not sure which version you need, but certainly not the latest)
          [  ] Expert level in C++ programming
          [  ] Loads and loads of hands-on experience with InDesign
          [  ] Understood the difference between Javascript and C++
          If you cannot answer all of these questions with a resounding "yes", you don't have enough experience to even get started, and you are better off paying someone to write a custom plugin for you.
          • 2. Re: script to plug-in
            Harbs. Level 6
            Let's not forget that "getting started" could take 3 to 6 months...
            Harbs
            • 3. Re: script to plug-in
              Harbs, do you know what happens when you write and compile a script with VBS or C#? Those get compiled into EXEs, don't they -- can they still be interrupted with Esc?
              (Perhaps Robin Tkaczyk -- www.adobescripts.com -- can answer that, although he's been off-line for a while.)
              • 4. Re: script to plug-in
                Marijan Tompa [tomaxxi] Level 4
                It's even hard to start with Flash Builder I tried to make panel, and everything went well, but never succeeded to connect it with InDesign. Then I tried some examples, but I failed again I just tried to retrieve active document name. Maybe one day I'll have more luck
                tomaxxi
                http://indisnip.wordpress.com/
                • 5. Re: script to plug-in
                  Techi Panda Level 2
                  Hi experts thanks a lot for your suggestions.
                  I have to learn some more in c++.
