1 Reply Latest reply on Sep 6, 2010 9:46 AM by daslicht
    Flex app menu proposals?
    christomanos
      I have an app which has 8 views.
      I need to make a menu to navigate this views.
      How should I go?
      Show in my main app create states and in each state include my view?
      Should I have my views as NavigatorContent of a viewstack and then use it as a dataprovider for a tabbar?
      How do you code it?
        • 1. Re: Flex app menu proposals?
          daslicht Level 2
          I have a main view container with viewstack which contain sub components.
          The simplest way imo is just to try and find out what works best.
          I tried so many different things and now things crystalized down to one solution.
          However, I think when I start building/desingning the the final Applikation I will have to try different appraches again.
          At the moment I just built the 'engine' for a Applikation and later I try to built a GUI in Catalyst.
          If that do not work I probably import swf's into Flash.
          Anyone ever created components in Flex and imported them into Flash ?
          Would be great to create reuseable Flash Components with inspector etc ...
          I will see
          Good Luck!
          Marc
