4 Replies Latest reply on Sep 7, 2010 3:21 PM by willm8655
    When to use data-binding and when to avoid it.
    willm8655 Level 1
      Hi, i've previously been using data binding quite extensively in some round about ways to get my required results. However this approach has been a bit hit and miss and i suspect it is not very fast!
      I have a HTTPService and a Component i want to display the data received from the service, at the moment my code looks like this (Sorry for the mess, i'm not sure how you insert code):
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx"
      initialize="handleInit()"
      <fx:Script>
      <![CDATA[
      import mx.rpc.events.ResultEvent;
      Bindable] private var data:String;
      private function handleInit():void {
      service.send();
      private function handleResult(event:ResultEvent):void {
      data = event.result.toString();
      </fx:Script>
      <fx:Declarations>
      <s:HTTPService id="service"
      url="
      myurlhere"
      result="handleResult(event)"
      resultFormat="
      text" />
      </fx:Declarations>
      <s:Label id="label"
      text="
      {data}" />
      </s:Application>
      I would change to simply assigning the data in the result handler by 'label.text = data' however this will give an error if the label component has not yet been created by the time the service result occurs. Is there a way to avoid using binding in this situation?
