2 Replies Latest reply: Sep 7, 2010 12:17 AM by EntWebDS RSS
    After Effects Crashes when trying to replace footage
    EntWebDS Community Member
      I recently got a new PC and the new computer has drive letters assigned to removeable drives that used to point to where my files were stored.  When I try to replace the footage, After Effects crashes and does not give me any option to send a crash report.  I updated to 10.0.1.19 and updated my video card driver (which fixed a problem with OpenGL not registering), but it did not solve my issue.  I can include the crash details here:
      Problem signature:
      Problem Event Name: APPCRASH
      Application Name: AfterFX.exe
      Application Version: 10.0.1.19
      Application Timestamp: 4c785da6
      Fault Module Name: PIN.dll
      Fault Module Version: 0.0.0.0
      Fault Module Timestamp: 4c785ba4
      Exception Code: c000041d
      Exception Offset: 00000000000635e5
      OS Version: 6.1.7600.2.0.0.256.48
      Locale ID: 1033
      Additional Information 1: 5bba
      Additional Information 2: 5bbaf7cb0c739be4571392021e7dd7af
      Additional Information 3: 9e45
      Additional Information 4: 9e45001b5e81db08a7f5aec534b583fa
      I can also offer the following information:
      Windows 7 Professional 64-bit
      Intel Core i7 860
      ATI Radeon HD 5770 1024MB (latest driver installed)
      1 TB Hard Drive
      8GB DDR3 Memory
      Any suggestions would be welcome.
        • 1. Re: After Effects Crashes when trying to replace footage
          Mylenium CommunityMVP
          What CoDecs, framerates and resolutions are the footage items? Does the crash still occur, when you try to replace the source from a fixed drive? I suspect it's an issue with the media cache due to eitehr the performance of the external drives being poor or some more generic driver issues that cause mayhem with them.
          Mylenium
          • 2. Re: After Effects Crashes when trying to replace footage
            Thanks for the insight.  "Performance of the external drives" was pretty close, I think.
            I believe it was due to the fact that when I created the project, the files were located on an external drive "F".  My new system designated drive "F" as one of the built-in card reader slots.  AE did not want to replace the source from the card reader unless 1) there was a card in the slot and 2) the original file (or one with the same name at least) was on the card. I wasn't about to go through all that heartache and discontent (I was missing about 30 files, and the 1GB card was nowhere close to big enough to hold the 9GB of data), so I used the Disk Management utility to reassign the drive letters.  Luckily I have a couple of external drives - one to assign to the source "F" drive and another to be the new target "M".  There was some creative shuffling that had to happen to get the connections right, but it made AE happy.
