1 Reply Latest reply on Sep 7, 2010 7:24 AM by krafttimd
    PopupManager UIComponent question
    jahnvi35
      i am new to flex. i have this requirement where user can click on some button and that (parent) component should come up in different flex window (not browser) .
      for example i have chart and when i click on chart it should open new TitleWindow with same chart. how can i achieve this ?
      i tried using popupManager and TitledWindow, it does open new opup window but remove that chart component from parent container .
      what is the best way to do this ?
        • 1. Re: PopupManager UIComponent question
          krafttimd Level 2
          You need to create a TitleWindow component and add an instance of the parent component. You may not be getting good results if you don't initialize the data that the chart in the popup window will need before having the new window open. So, before you pop the window make sure you set the data needed.
          Hope this helps,
          T.K.
