4 Replies Latest reply on Nov 8, 2010 4:55 PM by amandamariavoss
    Runtime Error 1007 on a simple ProgressBar in Flex 4
    Picsnapr
      This is such a simple code that compiles correctly, but I'm getting the error below when running it
      TypeError: Error #1007: Instantiation attempted on a non-constructor.
                      at mx.controls::ProgressBar/createChildren()[E:\dev\4.0.0\frameworks\projects\framework\src\ mx\controls\ProgressBar.as:1110]
                      at mx.core::UIComponent/initialize()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\ UIComponent.as:7250]
      Here's the code that gives this error:
      <s:TitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx"
         xmlns:com="com.*" xmlns:folders="services.folders.*"
         height.mini="80" height.full="400"
         minHeight.full="200" minHeight.mini="70"
         title="Upload Photos" creationComplete="initCom()"
         currentState="full" controlBarVisible="true"
         width="418" minWidth="400">
      <s:controlBarContent>
      <com:IconButton id="btnAdd" toolTip="Add file(s)" click="addFiles()" icon="{addIcon}"
                                skinClass="com.skins.IconButtonSkin" width="20"/>
      <com:IconButton id="btnRemove" toolTip="Remove file(s)" click="removeFiles()" icon="{removeIcon}"
      <mx:ProgressBar id="uploadProg" labelPlacement="center" width="100%"/>
      <com:IconButton id="btnCancel" toolTip="Cancel upload" icon="{cancelIcon}" click="onUploadCanceled()"
      <com:IconButton label="Upload" toolTip="Upload file(s)" id="btnUpload" icon="{uploadIcon}" click="uploadFiles()"
      <com:IconButton id="btnView" toolTip="Show/Hide file(s)" click="changeView()"
                                icon.full="{viewIconFull}" icon.mini="{viewIconMini}"
      </s:controlBarContent>
      </s:TitleWindow>
      If I remove the progressbar code from here, it runs fine. But with that one line, I get above error during runtime. With this line in, even the Design mode doesn't show-up in Flash Builder 4
      Any idea what could be the issue here?
      PS: I've tried with the normal s:Button as well, before the skinned button component. So obviously those can't be the problem.
        • 1. Re: Runtime Error 1007 on a simple ProgressBar in Flex 4
          Shongrunden Adobe Employee
          I'm not able to reproduce this error with the following sample:
                         xmlns:mx="library://ns.adobe.com/flex/mx">
              <s:TitleWindow title="Upload Photos" width="418" minWidth="400">
                      <s:Button id="btnAdd" toolTip="Add file(s)" width="20"/>
                      <s:Button id="btnRemove" toolTip="Remove file(s)" width="20"/>
                      <s:Button id="btnCancel" toolTip="Cancel upload"  width="20"/>
                      <s:Button label="Upload" toolTip="Upload file(s)" id="btnUpload" width="20"/>
                      <s:Button id="btnView" toolTip="Show/Hide file(s)"  width="20"/>
              </s:TitleWindow>
          </s:Application>
          Can you try to simplify your application to reproduce the issue in a small amount of code like this sample so we can investigate further?
          • 2. Re: Runtime Error 1007 on a simple ProgressBar in Flex 4
            Picsnapr Level 1
            Thanks for trying Shongruden,
            But I'm sure you couldn't reproduce, 'cause it seems like a bug with Flex 4 Spark components working alongside the old mx halo components.
            It seems the issues was because of the fact that I had multiple SWF's in my project.
            All I did to fix the issues is to add  maskSkin="mx.skins.halo.ProgressMaskSkin" to my ProgressBar tag!
            It seems the absense of a skin specification on the progressbar failed to initialize it. So just giving it the default skin made it work...
            Anyone knows of a bug like this, with the spark components?
            • 3. Re: Runtime Error 1007 on a simple ProgressBar in Flex 4
              amandamariavoss
              I had exactly the same problem and adding the maskSkin property did the trick. Thanks so much for sharing!
              • 4. Re: Runtime Error 1007 on a simple ProgressBar in Flex 4
                amandamariavoss Level 1
                Interestingly enough, this was only an issue when I changed themes. Reverting to my original theme also made the problem go away. The two I played with
                today are the two built in Adobe Halo Themes. AeonGraphical showed the #1007 error and reverting back to Halo made the problem go away.
