6 Replies Latest reply on Sep 13, 2010 8:44 AM by redwritergirl
    Font issue
    redwritergirl
      I am using Robohelp 8 - HTML  and generating Webhelp. I have changed my normal font to Arial 10pt, as well as other user defined fonts. This is correct in my style sheet as well. When I generate webhelp, my font size is larger in the output. If the .CSS is correct, what could be doing this? It's also correct in my inline text.
      - Diana
        • 1. Re: Font issue
          AlbusTeck Adobe Employee
          Hi redwritergirl
          Could you please confirm following:
          1. Remove the style sheet from the project and generate WebHelp, do you see the same issue?
          2. Sometimes it happens, that the same class is defined twice, so you are making changes in the previous one while lates one or say bottom one is having the bigger font size, which does have the impact. So please check if there are two classes of same name and remove the one which you don't require.
          3. Are you using any previous version project?
          4. Are you using RoboHelp HTML 8.0.2?
          4. Are you facing the same issue with any new fresh project? If yes then please share that with us, it will help us to understand the issue and will be able to replicate at our end.
          Regards
          Swaraj
          • 2. Re: Font issue
            redwritergirl Level 1
            Thanks!
            I am using version 8.02.208
            I just tried generating another project using WebHelp and I get the same issue.
            If I generate HTML help (.chm) the fonts are correct.
            I am also using the XP Blue skin.
             - Diana
            • 3. Re: Font issue
              Then could you please upload the sample project so that I can have a look in to that?
              Regards
              Swaraj
              • 4. Re: Font issue
                I figured out that for some reason my browser is displaying the fonts incorrectly on my computer only. So it must be a browser settting that changed. When access by other computers, the font displays as it should.
                • 5. Re: Font issue
                  Willam van Weelden Adobe Community Professional & MVP
                  - Is the font installed on your computer? If it isn't, the browser can't access it...
                  - If it is a browser setting, open Internet Explorer, go to Extra > Internet options > General > Accessability. (Names may vary since I translated this from my Dutch UI.) Uncheck all the boxes and press ok.
                  Greet,
                  Willam
                  • 6. Re: Font issue
                    Thanks, I did discover it is a browser setting issue as the font displays correctly on other computers.
