Our projects only use WebHelp and yet it won't allow me to delete the Flash skin. I can delete the folder directly using Windows Explorer, but then it shows broken in the Skins folder. Not a big deal in the big picture, but I always wondered why? and how?
Hi
Please do not use explorer always to remove or delete anything in the RoboHelp project.
So in this case could you please confirm if you have tried deleting Flash skin using following method?
1. Select the skin in Skins folder in the project set-up pod
2. Delete the skin
Please let me know about the results.
Regards
Swaraj
Hi there
Why are you concerned with deleting the skin? It's basically only consuming a small bit of disk space on your hard drive. Unless you have created FlashHelp output, the files will never been seen in your ouptut.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Answer to the first reply is it won't let you delete it from the Skins pod. Why I wanted to delete it was I am a neat freak and I have 15 builds and they all get checked into SVN. Therefore all taking up space. But its not a big deal, just thought I would ask.
