1 Reply Latest reply on Sep 7, 2010 10:07 PM by kglad
    Limit on line breaks in Dynamic ActionScript 2.0 string variables ?
    Claude_B Level 1
      Hello,
      I have a scroller window in my Flash file which uses a Dynamic string variable fed by a text.html file containing my variable  &about_readmore_txt2
      After running some tests with the text.html file, I noticed that after a certain number of line breaks (either entered by a "RETURN" or a <br />) the final text rendered when the Flash is played becomes erratic. It only displays a portion of the text in the middle of the scrolling window.
      The tests have been run using both options : Rendered as html and not. My tests also shows that this behavior is line breaks related (I shrank the content of the variable down to a point where everything comes back to normal and then, if I add another line break, it starts behaving erraticly again.)
      Any idea how to resolve this issue ?
      Claude_B
