5 Replies Latest reply on Sep 9, 2010 1:26 AM by Maximist
    property.state doesn't work
    Maximist Level 1
      Hallo everybody. I am using Flash Builder not since much time but i learned basilar things.. One of these things is that if i have a flex component and in my applications i have 2 states, state1 and state2, if i want to change a property (es. width) of that component in state1 and i wish it can be different in state2 i can write like this:
      width.state1
      width.state2
      This works always. Now, i just created my own component. The name of this component is "mioPannello":
      <s:Panel xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
           <![CDATA[
                public var rett_titolo_bottom:int;
                public var rett_centrale_top:int;
                public var rett_centrale_bottom:int;
                public var font_label:Number;
      </fx:Script>
      </s:Panel>
      As you can see, i just created my 4 properties which i will use in my own skin. The name of this skin is "mioPannello_skin":
      <s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:s="library://ns.adobe.com/flex/spark" width="100%" height="100%" bottom="0" creationComplete="aCreazioneCompletata(event)">
          <s:states>
              <s:State name="normal" />
              <s:State name="disabled" />
          </s:states>
          <fx:Metadata>
              [HostComponent("componenti.mioPannello")]
          </fx:Metadata>
      <fx:Script>
      <![CDATA[
      import componenti.mioPannello;
      import mx.collections.ArrayList;
      import mx.events.FlexEvent;
      [Bindable]
      public function aCreazioneCompletata(event:FlexEvent):void
           this.rett_titolo.bottom = hostComponent.rett_titolo_bottom;
           this.rett_centrale.top = hostComponent.rett_centrale_top;
           this.rett_centrale.bottom = hostComponent.rett_centrale_bottom;
           this.font_label = hostComponent.font_label;
      </fx:Script>
      <s:Rect id="rett_sfondo" height="90%" width="100%" bottom="0">
      <s:fill>
      <s:SolidColor color="#BDCCD4"/>
      </s:fill>
      </s:Rect>
      <s:Rect id="rett_centrale" height="100%" width="90%" horizontalCenter="0">
      <s:stroke>
      <s:SolidColorStroke caps="none" color="#FFFFFF" joints="miter" miterLimit="10" weight="1"/>
      </s:stroke>
          </s:Rect>
          <s:Rect id="rett_titolo" alpha="0.71" height="100%" width="80%" top="0" horizontalCenter="0">
          <s:fill>
          <s:SolidColor color="#E8EBF2"/>
          </s:fill>
          </s:Rect>
          <s:Label id="titleDisplay"
      top="5"
          color="#FFFFFF"
          fontWeight="bold"
          fontFamily="Myriad Pro" fontSize="{font_label}"
          horizontalCenter="0"/>
      </s:SparkSkin>
      When i call my component in my application, i can set property values in this way:
      <componenti:mioPannello width="100%" height="100%" title="panel title" skinClass="skins.mioPannello_skin" rett_titolo_bottom="15" rett_centrale_bottom="10" rett_centrale_top="30" font_label="12"/>
      Everything works good if i have just 1 state, but if, in my application i have 2 states, state1 and state2, the code doesn't work. So, if i write:
      <componenti:mioPannello width="100%" height="100%" title="panel title" skinClass="skins.mioPannello_skin" rett_titolo_bottom.state2="5" rett_titolo_bottom="15" rett_centrale_bottom="10" rett_centrale_top="30" font_label="12"/>
      rett_titolo_bottom.state2="5" it should change in state2 (or not??) but it doesn't change... It takes always the value 15 as it is in main state.
      Why this thing happen??.. I though i just created a normal property... How can i change that property in each different state. I hope you understand my problem and can help me..
      Sry for bad english
      Thx for all
      Max
