4 Replies Latest reply on Sep 9, 2010 1:50 AM by RUSH-ME
    popups
    gayathri_
      How do you pass a variable(say a String) from a module to a popup in another mxml?
      In the main mxml i have :
      public function createPopUp():void
                      PopUpManager.createPopUp(this, Mymodule, false);
      In the module  named Mymodule i have a statement
      parentApplication.createPopUp();
      The mxml for popup begins like this
      <?xml version="1.0"?>
      <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="PopUpManager.centerPopUp(this);" showCloseButton="true"
                      close="PopUpManager.removePopUp(this)" width="365" height="250" title="Result" >
      I want the string passed from the module to be displayed as a message on the pop up.
        • 1. Re: popups
          RUSH-ME Level 3
          Hi
          You can create a public variable in parent application and assign  value from module by calling parentapplication.var_name = value;
          PopupManager.createPopup returns an object of your popup.
          var myPopup:MyModule = PopUpManager.createPopUp(this, Mymodule, false); //MyModule should be the class name of the popup
          myPopup.var_name = parentapplication.var_name;
          Hope this helps.
          Rush-me
          • 2. Re: popups
            gayathri_ Level 1
            I tried that but i am getting the following error
            1118: Implicit coercion of a value with static type mx.core:IFlexDisplayObject to a possibly unrelated type DisplayResult.    LearningProject.mxml    /LearningProject_Aparna_1/src    line 40    Flex Problem
            public function createPopUp(test:String):void
                            //dr.loading(test);
                            var myPopup:DisplayResult=PopUpManager.createPopUp(this, DisplayResult, false);
                            myPopup.text = test;
            • 3. Re: popups
              flex4 Level 2
              Hi Gayathri.
                       If my understanding is correct.. u want to access popup mxml file from module right .. if it is correct if u dont mind please post ur popup mxml code
                           there are different ways to access popup method in another mxml file .... thanks...
              • 4. Re: popups
                RUSH-ME Level 3
                Hi
                Type cast it...
                var myPopup:DisplayResult = DisplayResult(PopUpManager.createPopUp(this, DisplayResult, false));
                Hope this helps
                Rush-me
