3 Replies Latest reply on Sep 9, 2010 10:06 AM by randolph _azzopardi
    importing from premiere pro cs5 to after effects cs5
    randolph _azzopardi
      hi, can anyone help me with this problem?
      im editing some stuff in premiere pro cs5 and when i import it into after effects cs5 for colour correction and other effects all the transitions that i had from premiere will disappear. if someone can guide me step by step to this process it will be very helpful
      Randolph Azzopardi
        • 1. Re: importing from premiere pro cs5 to after effects cs5
          There's nothing to tell - if they disappear, they are not supported by AE and the program has no way of re-creating them using its own effects or layer stacking trickery. Read the online help for which transitions and effects are supported! The only way to retain everything is to use Dynamic Link, but at the cost of having one long "sequence" clip instead of separate layers. Simply put: the fault is with your workflow. You have jumped ahead to far by finishing up the project in PPro insrtead of leaving it a rough cut for CC in AE.
          Mylenium
          • 2. Re: importing from premiere pro cs5 to after effects cs5
            Todd_Kopriva Level 8
            As Mylenium suggests, there are many ways to move information between Premiere Pro and After Effects.They are all outlined on this page: "Working with After Effects and Premiere Pro"
            You didn't specify, but I'll assume as he did that you are exporting a Premiere Pro project from After Effects. That works by converting things from native After Effects to their equivalents in Premiere Pro; sometimes there isn't a good equivalent, so the conversion isn't perfect. The same conversion is done as is done for copying and pasting between After Effects and Premiere Pro. There's a set of tables that describe the conversions here.
            The way to get perfect fidelity is to either use Dynamic Link (as Mylenium suggested) or render and export a movie from After Effects and import that into Premiere Pro.
            • 3. Re: importing from premiere pro cs5 to after effects cs5
              randolph _azzopardi Level 1
              heh this is getting complicated for me to just do a little bit of colour correction. im still not a pro in after effects just novice and the best way for me to work i think is use the Curves, Levels and Hue in premiere. if i have some vfx to do on i particular scene i will take it to after effects by itself and use colour finesse 3 for colour correction
              Thanks both of you
              Randolph Azzopardi
