6 Replies Latest reply on Sep 14, 2010 3:09 AM by Arun Ganesh
    how to get the status of the button?
    pad_birk
      i want to know how to get the clicked status of the button? whether it is in clicked state or in unclicked state?
      For ex: i have the following code...
      <components:IconButton id="bold_btn" width="22" icon="@Embed('/assets/bold.png')" click="onBoldClick()" enabled="{this.loadCompleted}" toggle="true"/>
      how to find whether the bold button is clicked or not?
      this.bold_btn.????
        • 1. Re: how to get the status of the button?
          BhaskerChari Level 4
          Hi Isa,
          You can make use of a Boolean variable to acheive this functionlaity...check out the below simple example...
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                  layout="vertical"
                  verticalAlign="middle"
                  backgroundColor="white" width="100%">
              <mx:Script>
                  <![CDATA[
                   import mx.controls.Alert;
                   private var isBtnToggle:Boolean = false;
                   private function onButtonClick():void
              isBtnToggle = !isBtnToggle;
              if(isBtnToggle)
               btnToggle.label = "I am Toggled ON";
               Alert.show("Button is Toggled ON");
              else
               btnToggle.label = "I am Toggled OFF";
               Alert.show("Button is Toggled OFF");
              </mx:Script>
              <mx:Button id="btnToggle" label="I am Toggled OFF" toggle="true" click="onButtonClick()" />
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: how to get the status of the button?
            Arun Ganesh Level 3
            You can get it easily. Make sure that button's toggle property is set to true.
            You can get the clicked state,
            buttonInstanceId.selected -> it will return the boolean value
            Hope this will solve your problem
            • 3. Re: how to get the status of the button?
              pad_birk Level 1
              It worked
              Regards,
              Lakshmi
              • 4. Re: how to get the status of the button?
                Arun Ganesh Level 3
                Kindly mark it
                • 5. Re: How to access the components of one mxml to another mxml?
                  pad_birk Level 1
                  I have a component named storylist as below in StoryList.mxml
                  <mx:List id="storyList" width="100%" dataProvider="{this.currentDoc.stories}" height="100%" variableRowHeight="true" selectable="false" borderStyle="none"
                  itemRenderer="com.xxx.yyy.core.views.renderers.StoryRenderer">
                  </mx:List>
                  I want to access the storylist in another mxml CoreCanvas.mxml
                  private function onOpenFile (doc:IdmlDocument):void {
                  logger.info("onOpenFile");
                  this.editor.currentDoc = doc;
                  this.editor.storyList.dataProvider = this.editor.currentDoc.stories;
                  but when  i declared as a bindable variable in StoryList.mxml --> [Bindable] public var storyList:IdmlStory = null;
                  it gives an error
                  Description Resource Path Location Type
                  1151: A conflict exists with definition storyList in namespace internal. StoryList.mxml /WebEditorCore/src/com/xxx/yyy/core/views/editor line 10 Flex Problem
                  how can i access storylist in the other mxml file?
                  Message was edited by: Jochem van Dieten
                  • 6. Re: How to access the components of one mxml to another mxml?
                    Arun Ganesh Level 3
                    Where u add the StyleList component?
                    Send the tag here
