13 Replies Latest reply on Sep 9, 2010 8:06 AM by Maximist
    How to enable Mouse Scroll in List
    Maximist
      Hallo. I have a list and i can scroll it throw scroller or throw arrows (on keyboard), but how can i scroll all the elements with the mouse scroller??.. By default it doesn't work, how can i enable it?
      Thx
      Max
        • 1. Re: How to enable Mouse Scroll in List
          Arun Ganesh Level 3
          Try this
          private function onMouseWheel( evt:MouseEvent ) : void
                          var curScrollPos:Number = myList.verticalScrollPosition;
                          if (curScrollPos> 0 && curScrollPos< myList.maxVerticalScrollPosition)
                              curScrollPos+= evt.delta;
                          myList.verticalScrollPosition = curScrollPos;
          <mx:List mouseWheel="onMouseWheel(event)" id="myList"/>
          • 2. Re: How to enable Mouse Scroll in List
            Maximist Level 1
            Thx for help. I tried your code, but there is no property in my list named verticalScrollPosition...
            Why??
            Max
            • 3. Re: How to enable Mouse Scroll in List
              Arun Ganesh Level 3
              There is a property called 'verticalScrollPosition'.
              Can u share ur code here? I may find where the issue is?
              • 4. Re: How to enable Mouse Scroll in List
                Maximist Level 1
                Ok.. This is my List component:
                <s:List id="listaAreeBusiness_conces_lst" width="80%" height="82%" borderVisible="false" top="35" skinClass="skins.mioList_skin" horizontalCenter="0">
                When i try to do:
                this.listaAreeBusiness_conces_lst.verticalScrollPosition
                i receive a compile error which says that there is no property with name verticalScrollPosition... This is true also because, when i use the assist tool, i see all the properties and there is no verticalScrollPosition property... I don't understand why..
                please help me...and thx for all
                Max
                • 5. Re: How to enable Mouse Scroll in List
                  Arun Ganesh Level 3
                  Are you working on Spark list?
                  If it is means try,
                   myList.layout.verticalScrollPosition
                  • 6. Re: How to enable Mouse Scroll in List
                    Maximist Level 1
                    Ok...
                    Works fine for me... finally
                    But i can't find this other property you wrote in the code: maxVerticalScrollPosition
                    Where is this property??..
                    Thx
                    Max
                    • 7. Re: How to enable Mouse Scroll in List
                      Arun Ganesh Level 3
                      You can use your dataprovider length instead of maxVerticalScrollPosition
                      • 8. Re: How to enable Mouse Scroll in List
                        Maximist Level 1
                        Ok, now i don't receive any error message from compiler, but, when i run the program and use the mousewheel, nothing happen... absolutly nothing.. I paste here the code i am using so that u can correct:
                        this is my list:
                        <s:List id="listaUtentiFacebook_conces_lst" width="80%" height="82%" change="cambioItemAmiciFB_conces_Handler(event)" borderVisible="false" top="35" skinClass="skins.mioList_skin" horizontalCenter="0" mouseWheel="onMouseWheel(event)">
                        <s:layout>
                                  <s:VerticalLayout gap="3"/>
                        </s:layout>
                        <s:itemRenderer>
                             <fx:Component>
                                  <componenti:mioItemRenSoloTesto mioCampo="name"/>
                             </fx:Component>
                        </s:itemRenderer>
                        </s:List>
                        And this is my script code:
                                  var curScrollPos:Number = this.listaUtentiFacebook_conces_lst.layout.verticalScrollPosition;
                                  if (curScrollPos> 0 && curScrollPos< this.listaUtentiFacebook_conces_lst.dataProvider.length)
                                   this.listaUtentiFacebook_conces_lst.layout.verticalScrollPosition = curScrollPos;
                        What is my mistake??
                        Thx
                        Max
                        • 9. Re: How to enable Mouse Scroll in List
                          Maximist Level 1
                          I have just a new for you... I watched the help about the event mouseWheel and it says:
                          Dispatched when a mouse wheel is spun over an InteractiveObject instance. If the target is a text field, the text scrolls as the default behavior. Only available on Microsoft Windows operating systems.
                          Uhm.... I can use this event only with Microsoft Windows???... If yes, now i understand why it doesn't work for me.. I have a Mac... There is not a way with Mac??.. Is that possible??
                          Thx
                          Max
                          • 10. Re: How to enable Mouse Scroll in List
                            Arun Ganesh Level 3
                            trace the value of evt.delta, curScrollPos and let me know. I don't have flex 4 on my machine. thats the problem.
                            • 11. Re: How to enable Mouse Scroll in List
                              Maximist Level 1
                              Did you see my last message??... I have a Mac and maybe it is because of this that i have problems... I tried to trace the mouseWheel event but i don't get eny trace...it is like this event never happen... and this is because your code doesn't work... Maybe is The Mac the problem..
                              Max
                              • 12. Re: How to enable Mouse Scroll in List
                                Arun Ganesh Level 3
                                Now only check that message.
                                Stange one. Adobe have to fix that one.
                                • 13. Re: How to enable Mouse Scroll in List
                                  Maximist Level 1
                                  Yeah, i think too... Thx for all anyway and good work
                                  Max
