1 Reply Latest reply on Nov 20, 2017 7:30 AM by UfgPr
    Webengines: How to use cropMode
    Nathanaël Semhoun
      Hello,
      For my webengine, i need to crop the thumbnail. In sdk i seen cropMode (p. 135) but i don't know how to use it.
      I try to put it in galleryInfo.lrweb like, it's not work:
      ["photoSizes.thumb.cropMode"] = "minimum",
      Thanks for your help
        • 1. Re: Webengines: How to use cropMode
          UfgPr Level 1
          "minimum" should handle the given width and height as max values meaning they are somehow a box into which the output file should fit. So since aspect ratio is maintained either you don't use the height fully or the width. For a fixed height I use to set width to 9999.
          With "maximum" the output file will be at least width x height. So the the width x height box fits into the output box.
          Hope that's somehow comprehensible.
          That's at least what the docs say. I had strange results sometimes behaving like maximum when setting minimum, but that might have been side effects of other errors. When setting nothing it seems to use minimum.
