4 Replies Latest reply on Sep 21, 2010 4:27 AM by REM_DTP
    Help importing catalog data from a text file (import from csv, tab-delimited, excel)
    redddfoxxx
      Hi All-
      I've been banging my head on this one for a couple of days now. It seems like something that's probably been done before and shouldn't be all that difficult, but I've found little if any help in Adobe's documentation (and many many google searchs).
      I have a 100-page retail catalog with about 1000 products in InDesign CS5. I have an excel spreadsheet with this year's product names, prices, and updated descriptions. Normally, we would go through one-by-one and cut and paste. This year I thought I'd try to bypass that step. There are plugins that do this, but they're not cheap, and we're not big. Upgrading to CS5 from CS2 was a big investment in and of itself.
      Here's an example of the data (I'm using a pipe character as the delimiter):
      28392779|3627|super top|Get a handle on fun. Wind the cord around the spindle and let 'er rip.|6½” long
      |$10
      So... standard excel file exported to any delimited format (I actually use OpenOffice to do the export to avoid the problem of excel quoting damn near *everything*). In the InDesign file we have a text pane for each name, description and price grouped together. The group has a script label of the product ID and each field within the group is labeled accordingly (name, id, description). So, group: 3627, item: description (or name or price).
      Pseudo code:
        Open file
        Parse data into an array
        Step through InDesign file group by group
        Check group script label, Look it up in array, Assign values to fields
      Easy right?
      I'm not new to javascript, but it's not my strongest language. With this effort I've had problems as simple as syntax for identifying groups by their label. Anyway, here's the code (it ain't pretty as the only way I could even get it to run was to step through the data array line by line and then step through the entire InDesign file for each data line. And, yes, it takes about an hour to run -- but it *does* run):
      var myDocument = app.activeDocument;
      var datafile =  File("/Users/reddfoxx/Desktop/2010Sept8CatDesc.csv");
      datafile.open("r");
      var data = datafile.read()
      data = data.split("\n");
      // the data array is 0 indexed
      //  field 0 is the internal ID
      //  field 1 is the product ID
      //  field 2 is the product name
      //  field 3 is the description
      //  field 4 are the dimensions
      //  field 5 is the price
         for(x = 0; x < data.length; x++){
            data[x] = data[x].split("|");
            for(var z = 0; z < myDocument.groups.count(); z++) {
                if(myDocument.groups.item(z).label == data[x][1]) {
                     myGroup = myDocument.groups.item(z);
                     for(var y = 0; y < myGroup.textFrames.count(); y++) {
                        if(myGroup.textFrames.item(y).label == "name")
                             myGroup.textFrames.item(y).contents = data[x][2];
                        if(myGroup.textFrames.item(y).label == "description")
                             myGroup.textFrames.item(y).contents = data[x][3];
                        if(myGroup.textFrames.item(y).label == "dimensions")
                             myGroup.textFrames.item(y).contents = data[x][4];
                        if(myGroup.textFrames.item(y).label == "price")
                             myGroup.textFrames.item(y).contents = data[x][5];
      For anyone who's unfamiliar with groups and scripting, unfortunately, you can't address the text frames inside a group without using the group. At least, that's what I understand.
      Any help would be much appreciated. Even just figuring out how to address a particular group in the document, so that I don't have to step through the entire file and do a compare for every item would be a vast improvement.
      Thanks in advance.
      -Redd
