12 Replies Latest reply on Sep 10, 2010 5:16 PM by gagrinds
    VST Audio for CS5 SDK question
    gagrinds Level 1
      I have a couple of old audio plug-ins that ran on CS4.  I just recompiled my old VST library for 64 bit and built my plug-ins.  Everything went okay, but CS5 does not see them.  Is there a new VST library for CS5 or should I be doing something else?
      Gee
        • 1. Re: VST Audio for CS5 SDK question
          Zac Lam Adobe Employee
          Does the Premiere Pro plug-in loader see the plug-ins in the location you've installed them?  You can verify this by checking the Plugin Loading Log.  It'll be here on Vista:
          [user  folder]\AppData\Roaming\Adobe\Premiere Pro\5.0\Plugin Loading.log
          If you don't see your VST plug-ins mentioned in that log, we recommend the plug-ins be installed to the path pointed to by the registry key:
          HKEY_LOCAL_MACHINE/Software/VST
          Hope this helps,
          Zac
          • 2. Re: VST Audio for CS5 SDK question
            gagrinds Level 1
            Zac,
            In the examples you gave me years ago, I made following declaration:
            AEffect *main (audioMasterCallback audioMaster)
            In CS4 it complained so I made the following change:
            int *main (audioMasterCallback audioMaster)
            This worked in CS4 and the compiler stopped complaining.  However, it did not work in CS5.  I tried several other things, but it fails to load.
            What should it be?
            Gene
            Gene A. Grindstaff
            Executive Manager
            Security, Government & Infrastructure (SG&I) Division
            Intergraph Corporation
            PO Box 6695, Huntsville, AL 35813 USA
            P 1.256.730.6983 F 1.256.730.8046 M 1.256.566.5376
            gene.grindstaff@inergraph.com
            www.intergraph.com
            • 3. Re: VST Audio for CS5 SDK question
              Rallymax Level 2
              Don't know the answer but dllmain is to do with windows dll not adobe
              so I'd look for 64bit dll on msdn.Microsoft.com
              I dont know if you can have a main() anymore on win 64
              Quick search found this
              //  DllMain()  function  prototype.
              BOOL  WINAPI  DllMain  (  HINSTANCE  hinstDLL,
                 DWORD  fdwReason,  LPVOID  lpvReserved  );
              • 4. Re: VST Audio for CS5 SDK question
                gagrinds Level 1
                It also has dllmain for Windows loading, but the main() is the exported call back entry point.  However, the compiler complains that main() should be of type int not a structure pointer.  If you make it type int, it crashes CS4 and will not load on CS5.
                I just need to know how to work around this issue.
                Gene
                • 5. Re: VST Audio for CS5 SDK question
                  Rallymax Level 2
                  Can you change the name from main to something else? In exporteres the
                  callback is not called main.
                  I suspect that you're fighting the windows definition and adobes
                  callback definition. If u change the name it'll fix that.
                  • 6. Re: VST Audio for CS5 SDK question
                    gagrinds Level 1
                    Yes, I can change it, but I need to know the standard calling convention name that Adobe and VST expects to be there.  Does anyone know what it should be.
                    Gene
                    • 7. Re: VST Audio for CS5 SDK question
                      Rallymax Level 2
                      My guess is that it's AEFilter*
                      • 8. Re: VST Audio for CS5 SDK question
                        Rallymax Level 2
                        Sorry AEffect*
                        • 9. Re: VST Audio for CS5 SDK question
                          gagrinds Level 1
                          Yes, I know that it must be of type AEffecs*, but I presume it must have a standard name just like Premiere Pro video, transitions, etc. Have a standard name or callback.
                          Do know the name?
                          Gene
                          • 10. Re: VST Audio for CS5 SDK question
                            Rallymax Level 2
                            Can you post the .cpp file that Zac made for you?
                            It’s kinda hard to help you if I can’t work out what sort of callback you were trying to make.
                            Btw,
                            Based on your original post...
                            >AEffect *main (audioMasterCallback audioMaster) { ...
                            >int *main (audioMasterCallback audioMaster) { ...
                            ...I just grep'ed for the "audioMasterCallback" in all CS3|4|5 SDKs for AE and Premiere and it's not there.
                            I'm wondering how you compiled at all when there is no definition for it in the headers?
                            D:\My Downloads\Adobe\SDK>dir /ad
                            Volume in drive D is MEDIA
                            Volume Serial Number is E20D-79C1
                            Directory of D:\My Downloads\Adobe\SDK
                            09/10/2010  07:34 AM
                            09/10/2010 07:34 AM
                            01/24/2010 04:52 PM
                            Adobe After Effects CS3 SDK
                            09/10/2010 07:34 AM
                            Adobe After Effects CS4 SDK
                            09/10/2010 07:34 AM
                            Adobe After Effects CS5 Win SDK
                            01/24/2010 04:52 PM
                            Adobe Premiere Pro CS3 r1 SDK
                            09/10/2010 07:31 AM
                            Premiere Pro CS4 r1 SDK Win
                            09/10/2010 07:32 AM
                            Premiere Pro CS5 Win SDK
                            0 File(s) 0 bytes
                            8 Dir(s) 125,591,977,984 bytes free
                            grep audioMasterCallback . -rn
                            • 11. Re: VST Audio for CS5 SDK question
                              gagrinds Level 1
                              I am traveling this morning, so I cannot upload anything for a while.  Since the interface is defined in the VST documents, you probably will not find any documentation.  I did look in the includes an some of the VST documentation, but I did not see anything that would help.
                              When I get back to the office I will dump the entry points for one of Adobe's audio dlls and see what entry point it has.
                              I just thought one of you might have used the VST SDK and knew the answer.
                              Gene
                              • 12. Re: VST Audio for CS5 SDK question
                                gagrinds Level 1
                                The correct entry name is MAIN not main.
                                Gene
