1 Reply Latest reply on Sep 10, 2010 10:14 AM by Digital.Smith
    RemoteObject Scope Issue
    Digital.Smith
      I posted this in the ColdFusion forums earlier, but figured it might actually be better here in the Flex forums, so sorry for the repost.
      I am trying to create a backend for an AIR application. The application is a poker site. I can return objects from ColdFusion to AIR just fine, but the problem is, everytime I make a call to a function in my CFC, it acts as if each call is a seperate "instance" of the CFC.
      Below is the CFC I am using...
      <cfcomponent output="false" name="Deck">
      <cfset suits = ["hearts", "diamonds", "spades", "clubs"]>
      <cfset cards = ["A", "2", "3", "4", "5", "6", "7", "8", "9", "10", "J", "Q", "K"]>
      <cfset names = ["Ace", "Two", "Three", "Four", "Five", "Six", "Seven", "Eight", "Nine", "Ten", "Jack", "Queen", "King"]>
      <cfset deck = ArrayNew(1)>
      <cffunction name="CreateDeck" access="remote">
      <cfscript>ArrayClear(deck);</cfscript>
      <cfset cardsLength = ArrayLen(cards)/>
      <cfset suitsLength = ArrayLen(suits)/>
      <cfloop index="i" from="1" to=#suitsLength#>
      <cfloop index="j" from="1" to=#cardsLength#>
      <cfscript>
      ArrayAppend(deck, [cards[j],suits[i]]);
      </cfscript>
      </cfloop>
      </cfloop>
      <cfscript>ShuffleDeck();</cfscript>
      <cfreturn deck />
      </cffunction>
      <cffunction name="ShuffleDeck">
      <cfset CreateObject("java","java.util.Collections").Shuffle(deck)/>
      </cffunction>
      <cffunction name="DealCard" access="remote">
      <cfset randomNumber = RandRange(1, ArrayLen(deck), "SHA1PRNG")/>
      <cfreturn ArrayLen(deck)/>
      </cffunction>
      </cfcomponent>
      Below is a sample of the Flex code I am using to call the CFC...
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:mx="library://ns.adobe.com/flex/mx"
        creationComplete="initApp()">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      <s:RemoteObject id="svc" destination="ColdFusion" endpoint="http://localhost:8500/flex2gateway/" source="PokerSite.cfc.Deck">
      <s:method name="CreateDeck" result="resultHandler(event)" fault="faultHandler(event)"/>
      <s:method name="DealCard" result="resultHandler(event)" fault="faultHandler(event)"/>
      </s:RemoteObject>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      private function initApp():void
      svc.CreateDeck();
      private function doDeal():void
      svc.DealCard();
      private function resultHandler(e:ResultEvent):void
      trace(e.result);
      private function faultHandler(e:FaultEvent):void
      trace(e.fault);
      </fx:Script>
      <s:Panel x="0" y="0" width="250" height="200">
      <s:Button click="doDeal()" label="Deal"/>
      </s:Panel>
      </s:WindowedApplication>
      When I call the CreateDeck() function of the CFC, it returns the entire deck just fine. However, when I then call the DealCard() function by clicking the button, it returns a length of 0 of the deck object in the CFC (just returning the length to test that the deck has been created for now) as if the deck was never created. I did some searching online, and found that I might have to setup the remoting-config.xml file to allow application level scope. I then setup the remoting-config.xml like so...
      <destination id="ColdFusion">
      <channels>
      <channel ref="my-cfamf"/>
      </channels>
      <properties>
      <source>*</source>
      <scope>application</scope>
      </properties>
      </destination>
      Yet, this still fails the same way. Does anyone know if I am missing a simple step? Or setting up the application scope in the wrong place? It definitely sounds like the problem I am having, but when I change that remoting-config.xml file, it doesn't seem to change anything in the way the functions are called.
