1 Reply Latest reply on Sep 9, 2010 1:59 PM by Flex harUI
    rsl vs module
    lionh Level 1
      Hello,
      We have a big bank environment based on a J2EE/Spring server and JSP/JQuery/Flex client. The Flex lays in a jsp template. We have many Flex project with hierarchicals runtime shared libraries layers.
      When you access the main page of our web portal, on the top there's a javascript menu, wich let you access to the pure jsp or jsp template that load each flex application. A flex application could have one to many views.
      We have an application that have many and many views, and we want to separate (modularize) the main application with groups of views in modules. In the past, in the same case we would have made rsl to achieve this but we analized in the last days the possibility to work with modules and integrate the modules in our framework.
      The question is:
      What are the pros and cons working with modules and working with rsl. I know the technical differences so the question is more an architectural question.
      Thank you,
      Lionel
      P.S. Sorry for my bad english
        • 1. Re: rsl vs module
          Flex harUI Adobe Employee
          In Flex, an RSL is downloaded before the application starts.  If the RSL is
          not already cached, the end user has to wait longer to see the application.
          Modules can be loaded at any time, even after the application starts.  It is
          a great way to defer the download of code and assets not needed at startup
          time.
          Modules can be unloaded, RSLs cannot.  Therefore modules help you manage
          memory better.
          Modules that can be unloaded cannot share assets and data with other modules
          unless the classes for the assets and data are in a common
          applicationDomain.
          You can load a module into the main applicationDomain which means it cannot
          be unloaded, but then it will act like an RSL that got loaded after the
          application started.
          So depending on network speed (and don't forget intranet users working from
          home over VPN and DSL), you might want to use both RSLs and modules.  The
          RSLs contain classes that almost every app will use, especially if the RSL
          download time is not prohibitive.  Everything else goes into modules and
          classes that need to be shared between modules can be loaded into the main
          applicationDomain.
