5 Replies Latest reply on Sep 14, 2010 1:38 AM by OskarSaiz
    Using SOAP in Reader
    OskarSaiz Level 1
      Hi all.
      I've developed a simple application in a PDF using SOAP lo launch a web service.
      This does not work in reader, unless you have Form Export  Rights open”.
      To open these rights I've read that I need "Adobe LiveCycle Rights server", wich costs "hundreds to ten of hundreds dollars".
      Does anyone know an alternative to this?
      That is: Any other way to use web services in javascript in reader?
        • 1. Re: Using SOAP in Reader
          None of the Soap object properties are restricted, Only the some of the methods require 'Extended Reader Rights' and there are a couple of the methods that have enhanced security the will require an application level function or a certified PDF to be used. You can apply the Extended Reader Rights with Acrobat Pro 8 or Acrobat 9 Standard or higher. But if you use Acrobat, there is a limit on the number of copies of the PDF that can be distributed.
          • 2. Re: Using SOAP in Reader
            George_Johnson MVP & Adobe Community Professional
            Note that the right you need cannot be granted using Acrobat. You do indeed need to use LiveCycle Reader Extensions. But there is at least one third-party service (FormRouter.com) that will, for a fee, enable individual documents.
            • 3. Re: Using SOAP in Reader
              OskarSaiz Level 1
              I'm afraid I'm doing something wrong...
              It fails (in reader) in the first call:
              try {
              var myProxy = SOAP.connect("http://2203-19/ws2/service1.asmx?wsdl");
              } catch(e) {
              app.alert({
              cMsg: "Error connecting to the web service",
              cTitle: "My App"
              In Acrobat Pro Extended 9.0 it works OK.
              I granted "Extended Reader Rights" by doing: Advanced->Extend Features in Adobe Reader
              (It is the only similar thing I found. I wonder if I got right...).
              Any clue?
              Or any other way to communicate with a server, without using "LiveCycle Reader Extensions"?
              Thanks for all the advices...
              • 4. Re: Using SOAP in Reader
                I as I indicated earlier, you cannot use Acrobat to grant the right that will allow SOAP to work with Reader. Only LiveCycle Reader Extentions can.
                • 5. Re: Using SOAP in Reader
                  OskarSaiz Level 1
                  You're right George_Johnson. I will do it using forms instead of WebServices.
                  Thanks all for your help.
