2 Replies Latest reply on Mar 22, 2012 4:50 AM by Gabiango
    Command-line Compilation of Photoshop Panels
    encytemedia
      Hello,
      I'm attempting to create a Photoshop Panel using the Flex SDK and the mxmlc compiler.  I'd really love to avoid Flash Builder.  Here is the compilation line and the resulting error:
      ~/dev/shared/flex/bin/mxmlc --show-actionscript-warnings=true --strict=true -include-libraries=CSXSLibrary-2.0-sdk-3.4.swc -load-config=config.xml gridpanel.mxml
      Loading configuration file /Users/justin/dev/me/photoshop/gridpanel/config.xml
      /Users/justin/dev/me/photoshop/gridpanel/CSXSLibrary-2.0-sdk-3.4.swc(mx.core:IWindow)
      Error: Type was not found or was not a compile-time constant: NativeWindow.
      /Users/justin/dev/me/photoshop/gridpanel/CSXSLibrary-2.0-sdk-3.4.swc(mx.events:FlexNativeMenuEvent)
      Error: Type was not found or was not a compile-time constant: NativeMenu.
      Error: Type was not found or was not a compile-time constant: NativeMenuItem.
      /Users/justin/dev/me/photoshop/gridpanel/CSXSLibrary-2.0-sdk-3.4.swc(mx.controls:HTML)
      Error: Type was not found or was not a compile-time constant: HTMLHistoryItem.
      Error: Type was not found or was not a compile-time constant: HTMLUncaughtScriptExceptionEvent.
      Error: Type was not found or was not a compile-time constant: HTMLHost.
      /Users/justin/dev/me/photoshop/gridpanel/CSXSLibrary-2.0-sdk-3.4.swc(mx.managers:NativeDragManagerImpl)
      Error: Type was not found or was not a compile-time constant: NativeDragEvent.
      I don't have too much experience with Flex, but I'm guessing the CSXS library is using mx.* components that I haven't linked against.
      Here is the config file I'm using.  My flex SDK is located at "/Users/justin/dev/shared/flex/", hence the absolute paths in the config file.
      Out of desperation, I downloaded Flash Builder to see if I could inspect what compilation command it was running.  I had it dump the config file it was generating, and attempted to use it (it looks almost identical) and I ended up with the same error when trying to compile from the command line.
      For the sake of completness, I have a super basic MXML file.
      <?xml version="1.0" encoding="UTF-8"?>
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
      <!-- Copyright 2010 __MyCompanyName__. -->
      </mx:Application>
      Have any idea what I might be missing?
      - Thanks
